carb shim part needed ASAP - 1J712169V100
Discussion in 'XJ Technical Chat' started by Con1, Aug 22, 2007.
  1. Con1
    Con1 New Member
    Lethbridge, Ab
    got one hanging around???
    I believe it is a 3.15 MM shim??
    I need it in western canada ASAP thanks!
    email me con1@crystalclean.com
    Con
    THANK YOU!!
  2. ciscobird
    ciscobird Member
    Central Texas
    Need more info...
    You mean a 315?
    Also, is it a 29mm shim?
  3. RickCoMatic
    This confuses me?
    Carb Shim? Do you mean Valve Shim? A 290?
  4. MiCarl
    Good, was afraid I was the only one that never heard of a Carb Shim.
  5. Con1
    Con1 New Member
    Lethbridge, Ab
    sorry guys - I am no where near mechanically minded. when the mechanic at the Yamaha shop said he cannot complete my bike until this part was recieved - he said -shim - I assumed it was carb related. It is on back order & has been for 3 weeks now - with nothing appearing to coming soon I found out today.
    I know he said "He thinks it is a 315" & "shim" & part #1J712169V100 (81 XJ750)
    that is all I know
    it drives me nuts when a $5 part is preventing me from enjoying some cruising - all the other parts he needs are in.
    If you have access to one of these today - please advise me ASAP - even call me collect if needed 403 381 0015 (Pacific time!) not before 7:30 AM local - thx! (I am a night owl - not a morning bird)
    Con
  6. Robert
    Went through my stash of shims, closest I got is a 305. Sorry.
  7. RickCoMatic
    Yep.
    That's a Valve Adjusting Shim.
    It's the Biggest Shim they make for that Bike. 3.15
    I have a good idea that I'll be able to get it for you.
    So, let's be sure that ... that is exactly ... and ONLY what you need ... because this is a going to be an adventure for just one shim.
    Find out if there is anything else you need before I hit the road and go visit the Racing Boys for just one shim ... OK?
  8. RickCoMatic
    I called the Local Yamaha Dealership near me. No gots!
    I can get a 310 and a 320,
    Looks like that 315 is going to be an Oddball that we hope somebody has ... otherwise ... special order.
    Why not run another shim in there and let it be a little bit loose. Loose is better than Tight ... right???
  9. Con1
    Con1 New Member
    Lethbridge, Ab
    Just talked to the mechanic, definitely a 315.
    Please call me ASAP.
    Con
  10. chacal
  11. PghXJ
    PghXJ Member
    Pittsburgh PA
    get a 320 and sand it until it is a 315.
  12. ciscobird
    ciscobird Member
    Central Texas
    The diameter of shim is 29 mm. Just fyi.
  13. RickCoMatic
    I'm glad you got hooked-up. I called three places and nobody had it.
    That's a pretty plump shim you are putting in there. I wonder if the Cam Lobe is OK.
    There's a 310 and a 320, here, if you need them.
    Good luck with it.
  14. Con1
    Con1 New Member
    Lethbridge, Ab
    thanks chacal!!!!!!!
    part is ordered - now if it could just get to canada from georgia tonight I be happier!
    Con
  15. chacal
    Con, I'll do my best! But seriously, it will go out in tomorrow's mail!
    Thanks!
