Carburetor Drain Screws
Discussion in 'XJ Technical Chat' started by StahlMaster, Sep 17, 2006.
  1. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    XJ650J
    I'm looking for a couple of replacement drain screws for this bike. Also would like advice on removing a drain screw with chewed up slot.
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Two best ways to remove drain screws are 1. cut a new slot with a dremel tool or 2. drill out with an ezout.
  3. faighaigh
    faighaigh Member
    Malaga . Spain
    Hi.
    I bought 4 stainess steel drain plugs for my Hitachi carbs they are a bit long but do the job well. I think they cost $10.00 but I was quoted $40.00 for Yamaha plugs from a dealer.
    Contact this bloke stevec5000@yahoo.com
    Faighaigh.
  4. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
  5. faighaigh
    faighaigh Member
    Malaga . Spain
    Well it was $12.00 well spent.
    Faighaigh
  6. moctod
    moctod Member
    South Carolina
    I need 4 carburetor bowl drain screws for an XJ650 Maxim if anyone knows where I can get them. The head of one was so chewed up I had to drill it and remove with an easy out. Not an easy task but it worked.
  7. RickB
    RickB Member
    Southern Maryland
    Len (Chacal) from XJ4ever sells the best replacement drain screws on the planet. They were ~$32 including shipping for a set of 4, but are brilliant: stainless steel, with hex heads, and longer than the originals. These will never strip...
  8. schmuckaholic
    California
    O ye of little faith. :)
    They're still a great idea, and I have them on my 750. Look on page 4 of Setting The Fuel Levels for an idea of what they look like.
  9. Polock
  10. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Go with Len (chacal) for all your parts....
  11. RickB
    RickB Member
    Southern Maryland
    ...or your bike will not run properly and you will be unsafe; and for goodness sake, CHECK YOUR VALVES... :)
  12. moellear
    moellear Member
    Lima, Ohio
    this guy is still around. I got ahold of him for my hitachi carbs and was satisfied. honest working man who is capable of making the same carb screws with his lathe at a reasonable price. remember, a screw is a screw no matter where you get it from. i do know that mikuni carb bowl screws are difficult for him to make though, as he was not able to help me out with my 550
