carburetor synch
Discussion in 'XJ Modifications' started by mikey2021, Jun 6, 2012.
  1. mikey2021
    mikey2021 Member
    hannibal mo
    Ok my 81 xj650 is idleing good now and I was woundering about the vaccum synch I could not find a how to forum on it if some one could enlighten me a little bit it would be much help oh I got a carb synchronizer with the four gauges
  2. wizard
    Line up 1 & 2, then do 3 & 4, then line up the 2 pairs with the middle screw.
  3. CadMonster650
    CadMonster650 New Member
    Carver, Minnesota
    My bike runs pretty decent, but I know my carbs need to be synced. However, I'm not even going to bother until i get the valves in spec as well as the float heights. make sure those things are dialed in before syncing and life will be good.
  4. mikey2021
    mikey2021 Member
    hannibal mo
    Ok cool and what about the vaccum line into the petcock how do I keep gas flowing with the vac line out and I use the same synch screws that I bench synched with right
  5. bigfitz52
    Put the petcock on PRI and yes.
  6. mikey2021
    mikey2021 Member
    hannibal mo
    Ok I sent to synch the carbs using the gauges and the needles. Just bounce back and forth is there a way to slow them down or make them easier to read
  7. bigfitz52
    You'll need to add "restrictors" in the lines. You can use small bits of plastic spray-straw wrapped in tape to make them big enough to fit tightly in the line.
  8. mikey2021
    mikey2021 Member
    hannibal mo
    Do the cut pieces need to be a certain length
  9. bigfitz52
    nope, just all the same. Probably like 3/8"~1/2" long would do. Long enough to push the lines back on from each side and get a good seal.
  10. mikey2021
    mikey2021 Member
    hannibal mo
    Ok so I got tje idle down to 1500 and once u hit the throttle it dies
  11. autosdafe
    autosdafe Member
    Lorain OH
    Is the bike warmed up? You have to warm them up for it to hold a low idle. Also remember to adjust idle speed during sync . I found airline restrictos for fish tank airlines to work well on the sync gauge to keep the needles from dancing everywhere . I remember my first attempts at syncing. Man I learned a lot.
  12. mikey2021
    mikey2021 Member
    hannibal mo
    I have small hoses would putting a piece of smaller hose in them help restrict the needle movement
  13. wwj750
    wwj750 Member
    central minnesota
  14. mikey2021
    mikey2021 Member
    hannibal mo
    I tried it and they where still the same
  15. mikey2021
    mikey2021 Member
    hannibal mo
    I have replaced everything in each carb except the throttle seals but I ordered some from the site so after that there should be no reason for any leaks
  16. kevineleven
    kevineleven Member
    Columbus, Ohio
    Do you have a good seal carb to insulator to intake? Thats where the most trouble occurs. IIRC the #3 is static, you tune 4 to 3 then 1&2 then 1&2 to 3&4 via the center adjuster. All 4 should be dialed in pretty close, probably get within 95% or more accuracy. I use mercury sticks, so im not sure of the gauge style. They may be more (or less) accurate. I havent messed with my XJ carbs in years, set and forget.
  17. ArcheRD350
    ArcheRD350 New Member
    If you need a gauge to sync your carbs don't buy one but make one that worked well for me.
    Go here to see one style of carb sync tool but go to their download page to see another type. http://www.yamahabikersclub.com/forum/s ... p?tid=1571
    Live, love and ride Yamaha
