Carby questions
Discussion in 'XJ Technical Chat' started by havocgtr, Sep 5, 2010.
  1. havocgtr
    havocgtr New Member
    just discoverd the diaphrams in the carbs on my 81 xj 550 have holes in them and that there kinda expensive to replace are there carbs off of any other bikes that will work as replacement carbs?
  2. xyxj650
    xyxj650 Member
    Fergus Falls MN
    Depending on the size of the holes you may be able to repair them. If you go to a hardware store,walmart or a auto parts store you should be able to find "liquid" tape. The stuff works great!
    The slides from any xj550 maxim or seca should work. As for other bikes with the same slides, here you go:
    XC180K - 1983
    RIVA 180Z - XC180ZLC - 1984
    RIVA 180Z - XC180ZL - 1984
    RIVA 180 - XC180ZNC - 1985
    RIVA 180 - XC180ZN - 1985
    RIVA 180 - XC180NC - 1985
    RIVA 180 - XC180N - 1985
    RIVA 180 - XC180DNC - 1985
    RIVA 180 - XC180DN - 1985
  3. havocgtr
    havocgtr New Member
    hmmm i have some of that might have to give it a shot there just lillte holes it looks like there from where the diaphram has sat with a crease in it for so long
  4. RickCoMatic
    THE "RickCoMatic Patch" © 11.23.09
    You have to be well organized for this.
    Buy a Small Funnel
    Cut the "Neck" off ... Clean & Neat.
    Further cut the Neck Area so that the OUTSIDE Diameter of the Diaphragm Piston will pass through the Hole -- TIGHT FIT.
    For this FIX you need that Jig to be a PRECISION Cut.
    Diaphragm Rubber Repair:
    Clean the Rubber with isopropyl alcohol.
    Apply MASKING TAPE to the OPPOSITE SIDE of the Repair.
    (Holding the tear together > Perfectly.
    Cut a small Funnel to act as a form. <---< NEEDED!
    Tape the Rubber down on the Form.
    Make sure Rubber is not buckled or wrinkled.
    Salvage some "Repair Material"
    (I used a small section of Material cut from a Nylon Windbreaker)
    Cut-out a PATCH of Repair Material to COVER the TEAR.
    Sharp scissors.
    Coat the Rubber Diaphragm over the TEAR with a thin coat of LIQUID Electrical Tape.
    PRACTICE THIS MOVE BEFORE YOU DO THE REPAIR. YOU MUST BE ABLE TO WORK VERY QUICKLY AS THE LIQUID TAPE CURES LIGHTNING FAST.
    >> Quickly apply the Patch with TWEEZERS and "Iron-Out" any Air Bubble or wrinkle with a BIC Ball Point Pen (Cover and Blunt End)
    Smooth-out Patch.
    You don't get much time to do this.
    Once Dry:
    Apply 2nd Coat of Liquid Electrical Tape.
    When 1st side is dry ... repeat process on other side of Rubber ...
    BUT
    Don't Stick Tape on the Repair ... Just Smooth the Diaphragm Rubber Out.
    November 23, 2009
    "The RickCoMatic Patch"
    "If I can't fix it. ... it ain't broke."
    --- Will Rogers
  5. havocgtr
    havocgtr New Member
    well it looks like the diaphrams in my carbs are completely stuffed (falling apart literally very brittle) what i want to know is will the carbs off of a xj/fj 600 bolt up to my manifolds and run????
  6. xyxj650
    xyxj650 Member
    Fergus Falls MN
    no they will not work. Only carbs other than stock 550 carbs would be seca 550 carbs.
  7. bigfitz52
    Be careful. All Mikuni BS28's are NOT exactly alike.
    I'm not sure what the specs were on the "world market" XJ550s; the USA bikes (Seca and Maxim) had different pilot jets and needles from each other, probably because the Seca had hotter cams.
    I would suspect your bike is probably the same as a 550 Seca, but I would do some research first.
    PM me with an email address and I'll scan you all the "carb spec" stuff I have on the 550s.
  8. RickCoMatic
    I have had very good luck finding Replacement Diaphragms in Parts Carbs the Seller list: AS IS on Ebay.
    I have a stock of Carb Bodies I use when a Client sends-in his with a Broken Hinge Pillar.
