CDI -TCI -IGNITOR?
Discussion in 'XJ Technical Chat' started by skw1972, Aug 17, 2011.
  1. skw1972
    skw1972 Member
    Milton Florida
    whats the difference in a CDI and a TCI or an IC IGNITOR? I followed polocks test and got alot of open stuff whats up with the difference in these things?
  2. RickCoMatic
  3. skw1972
    skw1972 Member
    Milton Florida
    ok I get that (and the link will be good learnig) so a tci is a IC ignitor?
  4. darkfibre
    darkfibre Member
    Perth, Australia
    When talking about XJs, yes
  5. MiCarl
    In the parts fiche Yamaha seems to call all their ignition modules IGNITER. The parts list doesn't give any clues as to the technology in it.
    As far as I know there are three types of non breaker point ignitions Yamaha has used:
    CDI - Capacitor Discharge Ignition (mostly in the 70s)
    TCI - Transistor Controlled Ignition (mostly in the 80s)
    Computerized - One pick up coil and a processor that calculates when to fire each plug. Started to show up around 1990.
  6. SQLGuy
    SQLGuy Well-Known Member
    As others have said, TCI and CDI are both types of igniters.
    CDI may have been used more in earlier Yamahas, but it was used much later in a lot of other bikes, and has, IMO, definite advantages over TCI.
    TCI is a solid state Kettering ignition system (like points, and vacuum advance, but without the moving parts). It uses 12V to charge induction coils (dwell), and fires them by stopping the charging.
    CDI uses much higher voltage (200V or so), built up in the igniter, to fire a pulse into step-up transformers (the coils). Because you get spark when you fire the pulse, rather than when you stop charging the coil, there are no considerations about dwell time, and, depending on how the higher voltage is built up, you don't have the diminishing time window to charge the coils that you do at higher RPM's under TCI.
    My '83 GPz, for example, uses CDI.
  7. andrewlong
    andrewlong Member
    Cumming, GA
    The Seca II uses CDI
    It also uses magic, but all my magic is gone
  8. skw1972
    skw1972 Member
    Milton Florida
    why do I feel like I'd rather have CDI? I guess I need to get one either way if this one turns out bad I'll need it and if it's o.k I'll worry about it going on strike when Im 60 miles from home. well the bike started its re-assembly tonight and as soon as I get my exhaust shims, doughnut gaskets, and a battery I guess Ill know for sure. just feel like its toast cause my meter read alot of opens. Ive learned alot with this "bring the old girl back to life project" and if I knew then what I know now I would absolutley go for it again. time and money well spent, just wish the money part would ease up a little.
  9. todd
    todd Member
    Irvine,Ca
    If you're having problems with your TCI, Pm Robert (site moderator). He's the man who can fix you right up. He fixed mine quickly and at a reasonable price. The dude knows his stuff.
    Todd
    1980 xj650 Maxim
  10. skw1972
    skw1972 Member
    Milton Florida
    Really? I was just surfing the net to see if it could even be done thanks man!
  11. mmaxon888
    mmaxon888 New Member
    Fort Calhoun, NE
    Did Robert help you out?
  12. skw1972
    skw1972 Member
    Milton Florida
    hello. never got in touch. sadly my xj was totally destroyed this past December 20th, soon as the casts came off I was back riding, well a couple weeks after...
    but my seca is gone,
    I got a couple bikes to ride but I miss that one so so bad
  13. hogfiddles
    Hey SKW..........
    Sorry to hear THAT kind of news! So............what happened? I don't recall seeing or hearing anything about that.
    Now, here's a related question............happen to have any parts left over? I'm restoring a 650rj non-turbo now, and need a few things............
    Dave Fox
  14. skw1972
    skw1972 Member
    Milton Florida
    no bro, sorry I left the scene with my head taped to a board. last I saw the bike it was mangled pretty bad. Never went to the place that picked it up, I just let them have it. Would have broke my heart to see it that way.
    Im ridin a customized GL 1100 and a restored 1979 KZ 900...old one kick wonder..love it. Do miss my RJ 650 though
    I got hit on I 10, couldn't get out the way. Drunk guy in a dodge charger swooped in and I had pick up truck on my 6. I tied to catch the little shoulder but he just came over too fast, never looked to see if the lane was clear. Next thing I knew I was waking up with flash lights in my face and the chin piece of my modular was tore off, broke arm, 2 ribs and ankle, road rash and new bruises showing up everyday for 2 weeks.
    I got more power now though and the GL is nice and LOUD.
