cdi trouble
Discussion in 'XJ Technical Chat' started by 82 bobby, Jan 25, 2015.
  1. 82 bobby
    82 bobby New Member
    Bothell
    Can anyone tell me if a 81xj550 cdi box will work in an 82 xj650 and if so is the wiring the same as the xj650
  2. chacal
    No, absolutely not (both the TCI and the wiring harness). You do need to obtain the correct TCI box for your model bike, otherwise it will run horribly!
  3. 82 bobby
    82 bobby New Member
    Bothell
    okay thank you yeah some guy at bent bike told me it would work I figured I'd ask around and see if it was true
  4. mwhite74
    mwhite74 Member
    That being said, you should be able to use one from a 82-83 xj650 or 81-83 xj750, so you have some options (yics designation engines) . You could even go aftermarket which some members have done. For used ones just make sure the numbers match. I believe there's a 3 digit batch number stamp. but that's only signifying well, different batches.
    For me I used a tci from my old xj650 on my 750 seca with no issues.
  5. 82 bobby
    82 bobby New Member
    Bothell
    Ok thank you
  6. obed martinez
    obed martinez New Member
    Houston
    Hey guys, would an 81 xj650 wiring harness work for an 82 xj650?!
  7. MiCarl
    Not without some modifications.
  8. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    I have one that don't work for my bike anymore because I chnage the harness
  9. oobondooo
    oobondooo Member
    MIAMI FLORIDA
    If you interested DM
  10. hogfiddles
    I don't believe it's a swap.
