Center stand
Discussion in 'XJ Technical Chat' started by Bjarvis, Nov 18, 2012.
  1. Bjarvis
    Bjarvis Member
    Victoria BC Canada
    The PO installed a 4 to 1 exhaust (XJ650) and also has removed the center stand. I would like to put a center stand back on, but am wondering if it will fit with the 4 to 1 exhaust ?
  2. mtnbikecrazy55
    it should, ive seen quite a few bikes with 4-1's on them with a centerstand still
  3. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    If you can figure out the brand of the exhaust you could try their website and see if they have info that says it will work. I have heard of some "headers" that require the removal of the centre stand to mount the system.
    Just a thought.
  4. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Just put it back on, like try and mock it up and you will have your answer. I think mine could have stayed with my 4-into-1 config, but I didn't want it there.
  5. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Almost all 4 into 1's are designed to be used with a C-stand. Some aftermarket straight pipes or systems with collectors on some bikes don't have the bottom gaurd where the stand can contact the pipes and rub a hole, so that can be an issue. But typically the whole assembly of a 4-1 is out of the way anyway.
    The PO probably took off the center stand for other reasons, like he 'thought' it was slowing him down, or he didn't plan on doing any 'real' maintenance :p
  6. Bjarvis
    Bjarvis Member
    Victoria BC Canada
    Does anyone know if the center stand off a 1982 xj650 seca will fit the 1980 xj650 maxim ?
    Matt: I would try and put the original back on or mock it up - but it didn't come with the bike, PO took it off. Looking on eBay for a replacement.
  7. bigfitz52
