Centre stand bolt size
Discussion in 'XJ Technical Chat' started by SqBobSpongePants, Jan 3, 2026.
Tags:
  1. SqBobSpongePants
    SqBobSpongePants New Member
    Bodmin Road
    Hi all,
    I'm trying to find the size of the 2 bolts that fix the centre stand to a 1980 XJ650 4KO (Seca).
    Google AI search returns the following but the sources are a mismatch.
    "The Yamaha XJ650 center stand uses a M10 (10mm diameter) bolt with a 1.25mm thread pitch. The specific length can vary by year or stand design (e.g., side stand bolts on similar models can be around 11mm in thread length), but the pivot section is generally a M10 size. "
  2. Simmy
    Get the specific Yamaha bolt.
    They have a shoulder which forms the hinge pin for your stand.
  3. SqBobSpongePants
    Bodmin Road
    Thanks but your description doesn't match the part listed on websites that offer the part.
    Example
    https://www.cmsnl.com/en-gb/products/bolt-5x2_9701110020/
    Unless you think this is incorrect?
    I can't find the original yamaha part available anywhere in the UK. This is why I'm trying to establish the bolt specs.
  4. Simmy
  5. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    SqBobSpongePants likes this.
  6. SqBobSpongePants
    Bodmin Road
