centre stand help!
Discussion in 'XJ Technical Chat' started by maxim-man, Sep 2, 2014.
  1. maxim-man
    maxim-man Member
    ontario canada
    Hey guys, so I decided to put the centre stand on my 84 xj650. It came with the side stand on it already and my question is this:
    Is the same spring used for both stands? Having a real hard time getting this spring on the centre stand! See pic below!
    Thanks!
  2. bigfitz52
    Pic doesn't work.
    The centerstand spring is MUCH larger in diameter than the sidestand spring(s.) Short, large diameter coils, long "legs." And even the correct spring is a major pain to get installed.
  3. maxim-man
    maxim-man Member
    ontario canada
    Not sure what happened to pic but I see it there, anyhow guess I gotta hunt down a spring then! I wonder if anyone could post a pic of the correct one or maybe five me some measurements of one so I know what to look for!
    Thx
  5. maxim-man
    maxim-man Member
    ontario canada
  6. TIMEtoRIDE
    You put pennies or dimes into the spring coil with the stand "down", then put the stand up and unbolt - - the spring will have no tension.
    Carefully stretch the spring (just a little) using a come-a-long between a truck and a tree, or anything solid, insert some pennies - - install.
  7. BleedingOxide
    BleedingOxide Member
    Brighton UK
    I made an error installing the center stand & exhaust on my 550.
    I know its easier to install the spring with the centre stand "loose" and then line up the bolts but I had already installed the exhaust and you cant get to teh bolts with the exhaust in the way I was not going to undo it. (mufflers are hard-corroded onto the collector)
    So I got a chain and connected that to the spring, flipped the stand up and used my foot on the middle part of the chain to extend the spring while I puled on the far end of the chain.
    Not easy, but it worked.
    and now I have the chain permanently installed because the spring has captured it. (gonna get a dremel onto it)
  8. maxim-man
    maxim-man Member
    ontario canada
    Update, I put the spring on the bike and stand first and pulled the stand into place! I used the same spring that was on the side stand and seems to work well! Wasn't an easy task tho! Done nonetheless!
    Thx again for all the tips!
  9. quebecois59
    Don't forget to check it in a few weeks because the center stand is heavier than the side stand, your spring may get stretched and the stand may get too low.
  10. k-moe
    Pay close attention to any scraping sounds. That smaller spring may not hold the center stand well in a bumpy turn.
  11. maxim-man
    maxim-man Member
    ontario canada
    Thanks guys, I will definitely watch for this! Although I think I have the right spring, after seeing some pics on ebay they look very similar!
  12. hogfiddles
    hooking the spring on and then pulling the stand into place is how I used to do it, that was easy enough (long arms help), but now I just use one of my snowmobile spring pullers. Even easier.
    dave fox
  13. maxim-man
    maxim-man Member
    ontario canada
    I don't have those so had to use arm puller 1 and arm puller 2! Lol
    Thx
  14. hogfiddles
    It's a simple tool.... Probably one of my favorite ones--- no more fighting with springs on anything
  15. maxim-man
    maxim-man Member
    ontario canada
    Always handy to have the right tool.for the right job for sure!
    I made another thread about swing arm bearings, any chance you know about that?
    Thx Dave!
