Chain Guide pieces in shifter drum
Discussion in 'XJ Technical Chat' started by Special_edy, Apr 8, 2014.
  1. Special_edy
    Special_edy Member
    Arlington, Texas
    Ok so I've had the issue of intermittent jamming of my shifter and I finally removed the shifter cover to dig the pieces out.
    The problem I'm having is that there are two peices in there and they are both over one inch in size, perhaps just big enough that they wont fit through the hole above the shifter mechanism. Is there any other place I can migrate them to where I will have the clearance to remove them?
    Thanks in advance!
    Ed
  2. schmuckaholic
    California
    I've not had this issue, but AFAIK, the answer is no -- the pieces would need to be broken up. As they broke off in the first place, I would think that making them smaller shouldn't be a problem. :)
  3. adrian1
    adrian1 Active Member
    Until you fix it properly, suggest you carry the necessary fishing tools wherever you go!
