change gauges on yamaha xj 750
Discussion in 'XJ Modifications' started by Ghilteras, Nov 17, 2010.
  1. Ghilteras
    Ghilteras New Member
    hello there, I have a yamaha xj 750 and I'd like to remove the windshield and change the head light from a square one to a circular one thus making the bike a bit more "naked"
    that is to say like this:
    the problem is the dash gauges, I'd like to change them as well, those are the ones I use at the moment
    I think that something more minimal would fit it better for a naked bike, but I dont know what dash I could put in its place, maybe something from the maxim or the seca? Truth be said it must not be a yamaha piece at all cost, I'd be more than happy with anything compatible that can be easily bought, something minimal: a speedometer, a tachometer, a little clock and some leds for gas, neutral, beams and arrows
    any help could be insanely appreciated :)
  2. bigfitz52
    My Seca 550s are both "naked" and I like the stock cluster (although replacing the speedo was a must.)
  3. Ghilteras
    do you think that dash could be compatible with a xj 750? It's surely more minimalistic than mine. but I guess the clock is not part of it :)
    I guess you did replace the speedometer because the original one didnt go further 80 mph
  4. darkfibre
    darkfibre Member
    Perth, Australia
    Compatible is a relative term. This is my XJ750 dash but some mods were required.
  5. Ghilteras
    I mean compatible as: "a dash that could fit in place of mine with some easy mods that most mechanics could do"
    I am scouting ebay looking for something I could put on my bike, most of them are said to be "compatible with many models but please check"
    the thing is that I don't know how to check, that' why I am asking you guys here :)
    anyway that dash looks cute, which model is it? what kind of mods were required to make it work?
    cheers
  6. darkfibre
    darkfibre Member
    Perth, Australia
    Koso RX-1N dash
    custom bracket made
    Simplified Seca wiring
    Koso Electronic speedo adapter instead of cable.
    Had to modify fuel tank sender as well.
    Build thread is on here, search for pumba
