Chat room created.
Discussion in 'Hangout Lounge' started by MiCarl, Jan 8, 2008.
  1. MiCarl
    I created a chat room for us.
    LINK
  2. Polock
    snuggykin you gotta be kiddin me
    chat rooms aint me, you'll fall asleep waiting for me to type
  3. MiCarl
    Well this seems just about as successful as the Edsel.
  4. Polock
    ok, i tried it
    i like it
    still don't know how those kids do it so fast
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Recommended by four out of five XJers.
  6. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Yea, what he said!!!
  7. Gamuru
    Gamuru Guest
    Granite Falls, WA
    You can use the URL for your XJBikes.com avatar in there, too.
    1. Right-click your avatar
    2. select properties
    3. right-click the URL listed
    4. click select all
    5. right click again
    6. select copy
    then log into the chat room.
    Assuming you've already created an identity in the chat room using your XJBikes.com nickname, left-click your name. A popup window will be displayed. Over-paste the default image text listed under the picture textbox with your new avatar URL by hitting CTRL+V on the keyboard. That should do it. Your XJBikes avater will import and resize automatically.
  8. Rettic
    Rettic Member
    Boone, NC
    Just thought I would bump this up to the top again. I can say real time support is great, much easier than waiting on posts. I like it, it is a good way to meet other XJ fans. Log in, change your name, set your avatar, join the fun.
  9. flash1259
    flash1259 Member
    W.R. Wisconsin
    HELLO CARL
    FOR SOME REASON THE CHAT SITE I HAVE TO TYPE SLOW SO ALL THE LETTERS APPEAR BUT HERE I HAVE NO PROBLEM
  10. MiCarl
    The chat is flash based. Perhaps your machine doesn't have enough cycles left to support it.
    Try closing windows and applications.
  11. MiCarl
    I'm using an older (slower) computer in the shop. I've found that the chat room uses enough cycles that everything else becomes painfully slow.
  12. MiCarl
    Bump. Trying to lure the new members.
  13. schmuckaholic
    California
    Let's bump it again. If the site goes down or becomes unresponsive, we need a place to gather.
    More users would be a bonus. :)
  14. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    I've never seen a chatroom like that before. How do you use it and who is CutiePook?
  15. dustball
    dustball Member
    Oak Harbor, WA
    easy enough.. works good!
  16. kevineleven
    kevineleven Member
    Columbus, Ohio
    Probably be a bit more successful if you could get a link added to the main menu (look left) that takes you directly to it.
  17. dustball
    dustball Member
    Oak Harbor, WA
    or have the moderator put a sticky or link
  18. schmuckaholic
    California
  19. schmuckaholic
    California
  20. Zookie400
    Zookie400 Active Member
    Connecticut
    oops, i bumped the thread.
