For Sale Cheap!! 1982 xj 750 parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by STRYKER911, Feb 23, 2016.
  1. STRYKER911
    STRYKER911 New Member
    Orlando,FL
  2. STRYKER911
    Orlando,FL
    I don't need a lot for this just try to at least offer more than what it cost to ship
    Lights bars horns Atari
    Throttle with mirror
    Clutch with mirror
    Seat
    Tail fairing
    Wiring harness few wired cut in a few places
  3. Cant Register
    Cant Register Member
    washington
    I was only coasting about 8mph and tipped over. I couldn't believe it, but my fork bent. I'm looking for a good fork tube cheap (Selling bike). I need one for a 1983 XJ750. Wonder if this one is the same? How are the forks? You'd only need to send the top part.
    Chris.
    Chris, the Seca 750 fork tubes are common for '81-'83. Are you positive that the tubes are bent? Start a thread with pics. You would have had to hit the tube on the curb or a rock to bend it at that speed.
    Ray likes this.
  5. Cant Register
    washington
    I am absolutely positive they are bent. I know it's hard to believe, but it's true. I even took it to a friend, I didn't tell him, just had him look. He can see them bent also.
    Chris.
    Ray likes this.
  6. hogfiddles
    Then they were bent long before that.... And if the bike has gone down hard enough to bend the forks, there's a pretty good chance that you have sustained some frame damage, too. I'd check that closely. If your frame is out of whack, then you're riding on a very dangerous-platform.
    Dave f
  7. STRYKER911
    Orlando,FL
    sry not selling the forks
  8. hogfiddles
    If it's just so you can ride, not for a 'looks' or originality thing..... Consider swapping the forks from a 750 maxim.
  9. Palmer650#2
    Palmer650#2 Member
    Middletown, MD
    Put the upper tube in a press and straighten it. It worked perfectly on my CRF bent fork tube. I rolled the upper tube on a flat surface to find the high spot, marked it with a sharpie and straightened it out it in my friends press. Just a thought.
  10. Grimlock
    Grimlock New Member
    Michigan
    Do you have any of the headlight stuff left. I need the lens and the buckets and mounting hardware and mount, the whole setup.
  11. hogfiddles
    Grim lock--- for a 750 Seca? Maybe can help..... Start a private conversation with me
  12. Haapala
    Haapala Member
    WA-USA
    Is the Atari box working? Speedo, tach, etc.?
  13. Jonah
    Jonah New Member
    Parkersburg wv
    do you know if this uses the same starter motor as the xj650, and do you still have it?
  14. ThinkingTime
    ThinkingTime Member
    Canada
    I"m interested in the seat. PM sent.
  15. k-moe
    It does.
  16. greenchevy421
    greenchevy421 New Member
    canada
    How much for horns to Toronto?
