Cheapskate luggage
Discussion in 'XJ Modifications' started by Dave in Ireland, Aug 21, 2015.
  1. Dave in Ireland
    Ireland
    My XJ900 came with a Givi rack fitted, but no way in hell was I going to pay Givi prices for their plastic boxes, good as they are.
    I swapped over a Givi-clone box from the GS, and it fitted the top rack with a little mod here and there, but that left the side racks to fill. Standard side boxes from Givi and all their clones are far too wide for my taste and I prefer to keep the bike narrow, so this is what I did...
    I molished up a mount for a dimpled alloy suitcase, to match it to the Givi side rack mount. Found the perfect mounting plate material in the form of some engineering plastic from a local stockholder.
    The tongue of the Givi bracket pokes through the mount plate and the case, and is secured by a spring snap-ring pin inside. Anybody trying to nick this will have to destroy it to get it off.
    The width of the case is perfect - exactly the same as the tip of the bar.
    Hammer for scale :)
    Oh, and the 'engineering plastic' found in the kitchen place was a chopping board of 8mm thick HDPE...
    One down; one to go, and I might make others up for at least one other bike. For this one, I need to find another dimpled case, as it's very tough construction, whereas the normal mainstream ally cases are composite (ally sheathed plywood) and not all that weatherproof.
    Xythin likes this.
  2. Polock
    put some little chains on the lid so the hinges don't get sprung when you open it.
    nice job
  3. Dave in Ireland
    Ireland
    Oh yes, good spot.
    There were probably some restrainers there, at some time. Whoever gutted the foam out got rid of them.
    I think I've found a suitable matching (nearly) case for the other side, so will pick that up next week, with any luck.
    If you ever want waterproof you can adapt a Pelican, Seahorse, or other similar case in basically the same way.
  5. Dave in Ireland
    Ireland
    Pelican cases here are nearly the same price as Givi boxes, which is why I used what I had available. Even used Pelican cases fetch stupid money, because everybody thinks they want to bulid a RTW with Joe bike.
    It's not an Adventure Luggage solution, but purely for picking stuff up with - like weekly shopping trip etc.
    As it turns out the other box I have in sight for a close match to the first, is an ex-military case that contained a bit of comms kit, so is cheap.
