Checking a headlight
Discussion in 'XJ Technical Chat' started by EarlGrey, Jul 21, 2011.
  1. EarlGrey
    EarlGrey Member
    East Liverpool Ohio
    I know this one is going to have some of you shaking your heads, but if I have my headlight off the front, put a wire on one of the poles and stick the other end on the battery, shouldn't it light up? I'm starting to suspect that even though the filament is in one piece the headlight is still bad.
  2. hogfiddles
    there are two filaments in the bulb...one for low beam and the other for high beam. There should be three poles on the back of your bulb....one ground, one pos. for low, the other pos. for high.
    I wouldn't go directly to the bulb from the battery as the amps may kill it. Maybe not, but I wouldn't do it anyway.
    dave
  3. iandmac
    iandmac Member
    Brisbane Australia
    There's nothing wrong with testing your lamp or any other device this way, the current will be limited by the resistance of the filament. Be careful not to short the leads or you may damage your battery or create big sparks that can start a fuel fire.
    An easier and less dramatic way is to test the resistance of the filament of the lamp with your test meter. If it is open circuit, that is, an infinite resistance, the filament or the connections to it are broken. Any device designed for 12 volt operation will normally show a few ohms resistance only.
  4. RickCoMatic
    Use a Multi-Meter.
    That will tell you if the Bulbs Good or Bad.
    So will one of these:
    RadioShack
  5. EarlGrey
    EarlGrey Member
    East Liverpool Ohio
    Thanks guys. I'm going back out there after dinner. Are these standard lights you can pick up at Wal Mart if they're bad or are they a special order deal?
  6. SQLGuy
    SQLGuy Well-Known Member
    You should be able to get a replacement bulb at Wal-Mart, Autozone, etc.
    If it's a Seca 650, it's an H4 bulb (I think), 60/55W.
    If it's a Maxim, it's a sealed beam unit, 50/40W
    You might want to update your signature to clarify which model.
    Cheers,
    Paul
  7. biggs500
    biggs500 Active Member
    Sherwood WI
    H4 is correct for the Seca. Not sure on the Maxim.
  8. fxallen
    fxallen New Member
    Manitouwadge, Ontario
    Anyone know of flasher units that are available that cycle between low
    and high beam for daytime running light ??
    Fred
    85 XJ750XN
  9. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    No on that flasher
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    THAT would be awesome, if there was something like that available.
    A relay say, with a photo-resister that you mounted, that would turn your hi beams to low when it got dark enough.
