Checking oil level, when bike is warmed up or cold???
Discussion in 'XJ Technical Chat' started by Mitchhill, Jun 22, 2006.
  1. Mitchhill
    Mitchhill New Member
    Bellingham, WA
    This is a stupid question but are you supposed get an accurate oil reading after the bike is warmed up? I my bike sits overnight the oil level reads low, however if you ride it for 5 minutes then the oil level reads high. I searched this and found no answers. Haynes manual also doesn't say.
    Insight is greatly appreciated.
  2. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    It should read 3/4 of the way up the glass when cold and on the centerstand.
  3. Robert
    Good question. I'm going to suggest you should check it cold since the warm oil might give you a little bit of error owing to expansion and the capillary action of the warm oil.
