Chipped oil filter housing...
Discussion in 'XJ Technical Chat' started by das5150, May 25, 2015.
  1. das5150
    das5150 Member
    Winnipeg
    Alright guys, weigh in. Is this going to leak? If YES, what's the answer? JB Weld? Haha....
    Keep in mind it's temporary until my spin-on conversion gets here.
      File size:
      141.8 KB
      File size:
      122.7 KB
      20
      File size:
      104.8 KB
  2. Toomanybikes
    Tsawwassen bc
    Yes it's going to leak like mad wait for new kit. Not worth risking engine or life when it dumps oil on rear tire
  3. hogfiddles
  4. das5150
    das5150 Member
    Winnipeg
    OK. I figured, but thought I should confirm. I have the machine shop here at work taking a whack at it as well. Nothing to lose anyway...
  5. XJ550H
    just your motor, time to clean the bike, how long can it take until the spin on arrives?
  6. das5150
    das5150 Member
    Winnipeg
    What I'm saying is, we have a professional machine shop that can repair it like new, BUT... if they f*** it up that's fine because the spin on is on it's way!
  7. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I just installed the spin-on kit today. I think you shouldn't even bother with spending the effort of repairing the factory housing. The kit was really easy to install. Plus, with the correct filter, it has more than double the filtering effectiveness of the stock units. Besides, Len had my kit to my door within 4 days of ordering it. I recommend any XJ owner to get this UPGRADE.
  8. XJ550H
    what good will the spin on do you if you seize the motor?
    you asked for opinions but it is your call.
  9. wink1018
    Muncy, Pennsylvania
    Just let the bike sit for the few days of waiting for the spin-on kit you ordered.
  10. hogfiddles
    Uh.... Still can't wrap my head around that one---- are they professional or not? They want your money?---- they'll do it. With any guarantees? They do it out of the goodness of their hearts?---- they'd tell you to just wait til the new stuff arrives.
  11. k-moe
    The cost of a used housing is a lot less than the repair cost of the broken one will be (you'd be lucky to get it done for $100), but since its the shop at your job I understand why you asked. Just be patient and wait for the spin-on kit to arrive. If you want to use the broken housing as an opportunity to learn how to weld and machine aluminum then go for it.
  12. Toomanybikes
    Tsawwassen bc
    Aaaah yes grasshopper your time waiting has been rewarded
  13. das5150
    das5150 Member
    Winnipeg
    I work at a large facility that houses a full machine shop... I gave it to them. Cost is zero, so whatever.
  14. Polock
    well then, why did you buy one in the first place?
  15. XJ550H
    how did you break the filter housing?
