"Clean Your Own Carbs!" Old School Method by: Rick Massey
Discussion in 'XJ DIY How-To Instructions' started by RickCoMatic, Aug 28, 2006.
  1. RickCoMatic
    The Old School Method.
    By: Rick Massey
    All rights reserved.
    CLEAN YOUR OWN CARBS AND QUIT BITCHING ABOUT THEM!
    Pull the Gas Tank, Plastic’s and Beauty Pieces to get ready to remove Carbs.
    Get the Carbs off the bike. Major pain in the ass; this will be. Undo the clamps on the BOTH the Airbox – to – Carb boots and the Carbs – to – Manifolds.
    (Don’t mess with the Cap Screws trying to remove the Manifolds. It’s best to leave the Manifolds alone. Snap-off a Cap Screw and you’re screwed)
    Push the Air Box Boots back into the Airbox … noting the grooves in the Boots that fit the Airbox outlet air ports. This method causes the job to REMOVE the Carbs a whole hellava lot easier. Getting them back in the Grooves later requires a little fight. But, believe me … you’d rather fight with the Boots than remove the head for stud drilling-out.)
    Cables, Cable-end holders next. Clear the way to removing the Carbs from the LEFT side of the bike.
    Separate the Carbs from the Intake Manifolds.
    (Use a pry bar dressed to not mar any surfaces … or, add an Old School Tool to your toolbox. A hardwood hammer handle for a 16-Ounce Framing Hammer)*
    · Throw the handle in your toolbox. Use it to pry stuff on the bike for no metal to metal contact.
    Pry the #-1 and the #-4 back and free the Carbs from the Manifolds.
    Draw the Carbs straight back into the room you made by pushing-in those Boots.
    Bring the Carbs out the Left Side of the bike.
    FABRICATE:
    Get a rectangle bin to use for cleaning the Carbs. Wire-up and suspend a small cooking grate from a toaster-oven to set the Carbs on. This allows you to spray Carb Cleaner on them and have the cleaner and grime drip right off the Carbs into the bin.
    Set the rack on the grate and spray-off and brush-off all dust, dirt and grime.
    Hit the springs, adjustment screws, idle rod and the sync screws – real good so they respond to tuning adjustments, later.
    FABRICATE:
    Get two muffin baking tins – 12-holed – to set side-by-side – forming four columns of divided bins to store Carb component parts without mixing them up.
    NEXT: “We go where others fear to tread”
  2. Robert
    Nicely thought out Rick but could we go a little easier on the "sauce"? I can't wait for your next installment!
  3. ridz
    ridz Member
    Ride hard and live free!
    Outstanding man I for one am a stickler for the direct approach.
  4. ridz
    ridz Member
    Re: "Clean Your Own Carbs!" Old School Method by: Rick Mass
    Uh can I get a pictured diagram with please.lol
    Dre42 likes this.
  5. fyrman
    fyrman Member
    Midland, Michigan
    Sounds very helpful..
    This is going to help me through the winter, You should save as a document
    when you are finished and put in the download section......
  6. RickCoMatic
    Fuel Bowl Removal and Lower-End Overhaul
    "OK, Troops ... we're going-in!"
    Remove the four Cross-head (Or Phillips) screws holding the Fuel Bowl to the Carb Body.
    Set the four screws for Number - 1 in the bottom of your lined-up Muffin tin.
    Go ahead, take-off the Float Bowl.
    Spray cleaner in the Float Bowl letting it accumulate half-way ... set the bowl down -- level --and let the Carb Cleaner work on the Fuel Bowl's metering ports at the bottom.
    There's the business-end of your Carb exposed. The float is hinged. In the middle of the hinged part you'll see the "Float Needle Attaching Tab." There will be a tiny wire across the tab. That's a spring that is attached to the Float Needle Valve. Hold the Carb up and look at how that attaches to that tab.
    Between the two black floaters are the two Jets, and hidden from view by the Main Jet is an internal emulsion tube.*** (Emulsion tube will be referred to as NOZZLE in this article.) ***
    Below the Float Needle Tab is the Float Needle and the Float Valve Assembly.
    Slide the hinge pin out and drop it in the Float Bowl and let it soak.
    Carefully lift off the Float ... bringing the Float Needle straight up. Take the Float Needle and the Float and place them in the next bin.
    Being mindful that it is BRASS ... use the appropriate socket or boxed-end wrench and remove the Float Valve Assembly.***
    *** Depending on Year and Model the Float Valve may be: 1) Threaded 2) O-ringed and just pushed-in 3) Attached by a little forked holder and a screw,
    Upon removing the Valve; examine the end that was inside the Carb. On most Factory Valves ... there is a little, tiny, "Beanie-looking" screen filter. It comes off. Only take it off if it's rusted or you plan to lose it! Otherwise ... shoot cleaner through the body to blow-out the whole thing. Keep an eye on it when you shoot the cleaner to it!
    Put this Valve Body in with the Float and Needle ... save them together and don't let it get mixed-up with other Float parts.
    On the high post is the Main Jet.
    Wipe-off bottom of Main Jet. Read the engraved numbers on the bottom of the Main Jet and write down what that number is.
    There is a copper washer that the Main Jet holds in place.
    Remove the copper washer and store it in the next bin up. If the storage bin on the muffin tin is fluid tight ... spray carb cleaner in it and let the Jets soak in carb cleaner.
    The Lower Post:
    Smaller Jet than Main Jet.
    Wipe and record the number.
    Pull this Jet and let it soak, over there, with his buddies!
    Near the frame rail -- you'll see a very small diameter tube sticking-up from the Carb Body.
    That's a Siphon Tube. It has a very small fuel metering port at the top end. That tube extends into the well for it in the Float Bowl.
    The Siphon Tube, having such a small metering port ... and extended into the Float Bowl well -- supplies fuel to the top end. It's size and the relatively small volume of fuel within its supply well allow fuel to be drawn-up the Siphon Tube with the relatively low vacuum drawn on it when starting-up the engine.
    Well ... you cracked the Bottom-end and removed those parts ... Not bad. Everything needs to be cleaned, now. If your lucky ... there ain't much to do. On the other hand, if it looks like a Highway Crew passed through that Bowl and Bottom-end and did a nice job with putting-down tar ... its all got to go! Clean everything until it looks Brand New.
    To be continued.
    Old School Method Carb Cleaning
    By: Rick Massey
    Absolutely all rights reserved.
    Dre42 likes this.
  7. bigben750
    bigben750 New Member
    Grand Rapids, MI
    What if some how, the person cleaning the carbs put some parts into one carb cleaning container (not like I would do that or anything). Then put it back together not knowing which float, float needle, or diaphgram assembly went to what.
    Just wondering.
  8. RickCoMatic
    Since the parts are identical ... there might be no harm. Some float needles are NOT neoprene tipped. Some are solid brass. The brass ones have seated into the float valve, over time they might not be the same exact fit as one like it.
    You can put ALL the Jets in one bath of cleaner. The Jets have no specific differences.
    People replace carb parts off carbs they buy as "parts carbs" all the time. The idea is to allow a first-timer to see the process highly organized and lessen the fear of dealing with so many parts when it's time to put 'em together.
    Dre42 likes this.
  9. RickCoMatic
    Carb Cleaning - Continued
    By: Rick Massey
    Part 3
    "Overhauling Everything Topside"
    Before we even touch a screw to begin the work on the top-side; lets get the notebook and make a sketch. Believe me ... you WANT this sketch. (Or do a non-Old School and take a nice close-up picture of the 4-Hats, clips and hold-downs -- AND -- Especially, how the linkage to the four ENRICHMENT VALVES is oriented.
    (Tech Note: Enrichment Linkage -- Right to Left -- as viewed from the TOP of the Carbs with the Enrichment Circuit linkages TOP -- Carbs oriented 1,2,3,4 as you look at them on the bench)
    The 4 Enrichment Circuit Pivot Arms TOP.
    ROD extending through the four PIVOTS with 4 - FORKED, Valve-opening "fingers" BELOW the ROD ... and attached to the ROD with SET SCREWS which fit into DETENTS drilled to keep the SET SCREWS from slipping.
    Orientation of Parts:
    Right - to - Left -- RIGHT - to - LEFT
    #-4 Fork with set screw ++ Small Nylon Bushing ++ Pivot Arm ++ Large Nylon Bushing ++ Cable Pull Bracket ++ #-3 Fork with set screw ++ Pivot Arm ++ #-2 Fork with set screw ++ Pivot Arm ++ #-1 Fork with set screw ++ Pivot Arm.
    This mechanism is what is inaccurately called "CHOKE" by YAMAHA. But, since convention dictated that "Choking" was necessary to start a cold engine ... and, because CHOKE was easier for everybody to understand ... its called the CHOKE.
    You can now call it what it really is: The COLD-START ENRICHMENT VALVE CIRCUIT.
    Mark for Identification:
    Center Punch a dot at the RIGHT end of the ROD ... right in the middle of the flat spot at the very end. The center-punched "Dot" ... is to identify the RIGHT side of the ROD. The 20-seconds it takes to Punch the dot on the end will save you a lot of time trying to figure-out which end is what ... when we put everything back together. This is Old School Technique ... tape and marks from marking pens will be long-gone after the ROD is cleaned and overhauled. Your center-punched dot will be right there ... no mistakes ... next time; too!
    Remove the 4 - SET SCREWS attaching the FORKS to the ROD.
    Note the way that the CABLE PULL ARM attaches to the ROD. ("Reversed letter J"
    Remove the SCREW attaching the CABLE PULL ARM to the ROD.
    Slide ROD to the LEFT.
    Collect and save in order the parts which are attached to the rod.
    (Editors note: Those set-screws can be replaced with aftermarket standard hardware. I prefer small ALLEN CAP SCREWS -- most well-stocked hardware stores have them.
    Pimped: Black. Bling: Stainless)
    Next time: The Enrichment Valves come OUT!
    I hope my readers are finding this continuing set of articles clear and concise . I'd appreciate your remarks in the REMARKS THREAD -- Which I'd like to use as CHAT, now.
    Until next time on -- The Old School Method
    Your guide,
    Rick Massey
  10. RickCoMatic
    Carb Cleaning
    By: Rick Massey
    "Your life is about to be enriched"
    REMOVING THE ENRICHMENT VALVES and DIAPRAGM ASSEMBLIES.
    With the linkage for the Enrichment Valves removed. The four Enrichment Valves are exposed, along with access to the Pilot Screws ... just to the left of the Enrichment Valves.
    There will a Chapter devoted to the Pilot Screws, later. Right now, lets get on to the Enrichment Valves and continue the Carb Cleaning process.
    The Enrichment Valve each have a rubber dust boot covering them.
    Remove the rubber dust boots, which are best cleaned with dish detergent, rinsed -- dried, and soaked inside and out with Armoral.
    After removing the dust boots ... Remove the Enrichment Valves in order.
    These parts are Brass and may be very difficult to "Get started" out.
    Hold some torque on the wrench and whack the wrench with a hammer handle to supply impact to get these fittings moving out.
    The Brass housing comes out.
    Sometimes the complete Valve assembly will come out.
    Orientation:
    The Enrichment Valve is a Brass cylinder with an O-ring seal and a Pin-like protrusion on its business end.
    The upper section has a spring around the shaft of the valve stem which pushes closed the valve when the valve is closed by the relaxing of the cable controlling the linkage.
    The stem has a "T" shaped top that is channeled to allow the forks to open and close the valve.
    The valve should move very smoothly within its cylinder.
    The Top Hat -- "T" -- should be square at the top of the shaft and not deformed or bent. If it is deformed or bent ... great care must be exercised to straighten it. Roll the shaft on a flat surface and lightly tap in the "High side" to get the Top Hat squared-up atop the shaft.
    With the Enrichment Valves removed we move on to the Carb Top Covers.
    The Carb Top Covers are called: Hats. They can be shining chrome ... or, ugly looking, pitted old chrome. The ugly ones can be refinished and painted to look nice, again.
    Remove the four screws attaching the Hat to the Carb Body.
    If the screws are frozen ... DO NOT try to muscle them out. The top of the screw will break-off and you'll need to do drilling and tapping to get the chunk out and cut new threads for a new fastener.
    Use an impact tool if this is the case.
    When the four screws are withdrawn ... the Hat comes free and a long spring like a "Slinky" toy pops out like "Jack in the box."
    The spring is the Diaphragm Assembly return spring.
    Remove the spring and place it in your organizer tray.
    Exposed is the Diaphragm Assembly.
    Lift-out the edge of the rubber diaphragm from around the circumference of the carb body ... noting that there is a locating channel for the edge of the rubber diaphragm machined in the top of the body ... AND a locating TAB for the diaphragm to be correctly placed back in the cylinder upon reassembly.
    Carefully extract the diaphragm assembly taking GREAT CARE -- NOT -- to bend or otherwise damage the NEEDLE VALVE at the bottom of the cylinder.
    With the diaphragm assembly's removed and safely stored ... the Brass Nozzle -- into which the MAIN JET was attached at the bottom can be removed by inverting the rack and gently tapping the Nozzle -- UP -- through the TOP of the Carb body.
    Nozzles:
    Solid brass cylinders. Multiple tiny fuel metering ports. Some NOZZLES are "Slotted and Keyed" ... Others are simply "Press fitted" ... some are loose enough to fall out the top without even touching them.
    The NOZZLE is the POWER VALVE. Notice that there are 16 - 24 tiny metering ports drilled along the sides ... directly opposite from the ones on the other side. Hole the NOZZLE up to light. You must be able to see light through the ports near you coming through the ports on the opposite side. These very tiny metering port can be clogged with dried-out gas that forms a hard varnish-like substance.
    SOAK the NOZZLES for 30-minutes, completely submerged in carb cleaner before beginning to clean them with the correct fitting tool from the Welding Tip Cleaner set.
    Coming up next:
    Pilot Screw Removal ... Do's, Don't's and "Don't even think about its!"
    Rick Massey
  11. ronnieho
    ronnieho New Member
    this has been a big help,i just posted the big question of how to in xj chat, not brouseing the lounge yet. here lies most of my answers. now if you just post the rest of the story........... what kind of expense should ibe looking at?gaskets etc?????????????
  12. RickCoMatic
    By: Rick Massey
    PILOT SCREW REMOVAL / CLEANING
    Preface:
    There are three scenarios.
    1) Factory Anti-tamper Plugs still in place
    2) No Plugs. Screw slots visible and good.
    3) No Plugs. Screw slots visible and looking pretty shaky.
    As to #-1 above. There are pro's I know who will not disturb the plugs. They say: "They we're put there for a good reason. They get set right at the Factory and never need adjustment again." This is bullshit. All they want is the money from the next job without tweaking the one they should have.
    If you still have the infamous "Anti-tamper Plugs" in place ... remove them! Your bike cannot be fine-tuned with those plugs preventing you from making a precision mixture adjustment of the Pilot Screw.
    How do you remove them?
    I chuck a very small Number Drill into my Dremel Tool and go at that plug like a Dentist. The plug is about the width of a Dime or less! I touch the drill bit to the center of the plug very, very lightly. Once the tip of the drill penetrates through that thin plug ... you need to be able to STOP further penetration. The danger is doing harm to the Pilot Screw top beneath the plug.
    The slot of the soft, solid brass, Pilot Screw is right beneath that plug. Don't mess it up by touching the slotted top with the drill bit. Soft brass gets chewed-up by the drill bit really quickly. Faster than you can say, "Oops!"
    To get the plugs out; screw a sheet metal screw, or a dry wall screw into the hole and continue your Practice of Dentistry and extract it by pulling on the inserted screw with pliers, vice grips or a small "Slugging Handle." Wiggle and pull. The plug comes out and the Screw is visible.
    When you get the four plugs out ... oil the four holes with WD-40, or some other very light machine oil.
    SCREW TOP ARE VISIBLE AND LOOK GOOD.
    Don't start throwing the confetti around just yet.
    SCREW TOP'S VISIBLE AND LOOK PRETTY HACKED-UP
    Sound "General Quarter's" and get ready to do battle.
    The absolute, Number One Rule, for performing work on Pilot Screws is: "Use the right tool."
    If you have to run-out and buy a brand-new screwdriver, bring it home, and step right over to the grinder, to fabricate the necessary tool needed for Pilot Screw work ... so be it!
    You NEED a screwdriver that fits the slot at the top of that Pilot Screw with absolute precision. Make one. Grind, file, sand, shape ... do whatever you need to do to make the blade of the screwdriver fit the slot on the Pilot Screw with ZERO free-play. None.
    The wings on the top of the slotted screw are very soft brass. Unless the tool fits with such precision as to apply turning force to the entire mass of the screw ... the WINGS will move without the main body of the screw moving along with them. An ill-fitting tool will allow the wings to move "toward un-occupied space" without the body of the screw moving with them. They will bend. Any attempt to unbend them will break them right off the top. Bad news!
    Game time:
    Bottom line!
    One way or another, the Pilot Screws need to come out. They may be:
    a) Simply withdrawn. b) Removed with some dexterity and effort.
    c) Extricated; using all available resources ... maybe even the "Jaws of Life."
    If you are one of the lucky ones who had these screws protected by plugs; this might go as smooth as silk.
    Dab-out the puddle of WD-40 with a Q-Tip leaving a trace in there to help the process. Using the proper tool ... and, with a Watch-maker's gentle touch ... turn the screw IN. Yes; IN. In and down until the Pilot Screw "Bottoms-Out." As you do so ... count the revolutions needed for the screw to be turned IN until it bottoms. (Generally, this will be approximately two and one half [ 2-1/2 ] turns. If the adjustment is more or less; record the measurement for using as your preliminary adjustment OUT when the screw is replaced after Carb Cleaning. Do the same for all four.
    If you are less fortunate and find the plugs removed; but the Pilot Screw slots are in good condition. Clean-out the area above the top of the screw. Get the space meticulously clean. Use a generous amount of Carb Cleaner, and the point of a jumbo safety pin, that has had its tip heated and bent-over to be used as a surgical instrument. The entire space above the top of the screw needs to be meticulously cleaned -- with special attention to carefully scraping clean, the ULTRA -fine-threads above the screw.
    Once cleaned-out; flush-out with Carb Cleaner ... re-oil and attempt to turn the screw IN and DOWN as stated above. Using great care, attempt to get the screw to move. If it does move, attempt to bottom-out the screw as previously mentioned.
    + + + (If it does NOT move ... it is possible that someone could have left the screw already bottomed-out and not adjusted properly. If you are cleaning the set because the bike sat un-used for some time, runs like crap, stalls a great deal, was hard to start or would not idle ... it is possible that the screw IS bottomed-out and is the source of all that difficulty. If you suspect this is the case by comparing the height of the screw top to the others ... then, attempt to bring the screw OUT.) + + +
    If that screw doesn't move either way under gentle pressure ... STOP!
    Don't fool-around and "Chance-it." Get-out the Propane Torch ... time for heat!
    Clean-out the area of all the WD-40 with Carb Cleaner. When the Carb Cleaner evaporates apply several drops of -- >> OLIVE OIL << -- to the space above the screw top.
    The Olive Oil is a vegitable product; not a petrolumium based product. The Olive Oil will not ignite as readily as a petrolium based lubricant will; and will boil-away that which is not brass or aluminum while also acting as a penetrating lubricant.***
    Heat the surrounding aluminum area good. Sop-up the Olive Oil and make another attempt to move the screw. When it moves ... bring it UP into the oiled and heated area where it should begin to turn much easier allowing you to get it out of there. Forget about bottoming-it-out. At this point; you're better off -- "Getting them out."
    "Rescue-One, ParaMedic-One, respond to Hitachi Carbs ... reported severe head trauma ... Units respond Code-3"
    Now, we deal with the tough issue of getting-out Pilot screws that somebody really did a number on. There's good news; and there's bad news. The good news is that the Pilot Screw is made of Brass. The bad news is that the Pilot Screw is made of Brass, too!
    The damage is done. Before you arrived, somebody did a hack-job and "Screwed-Up" ... Big-Time. They bad-worded things up good. You're mission is to UN-bad-word the situation. Don't begin working on this project if you are angry or frustrated. You need to be in control and able to systematically perform the various steps we'll take to get them out.
    Job One is: "Get them OUT!" Period. We do what it takes to get them out and deal with all the other stuff -- later.
    Phase One: Take a shot. Your turn. Evaluate. If it looks like there might be enough of a slot left to back that thing out of there, or you might be able to do some Dremel Tool surgery to improve the situation -- have at it! Then, Olive Oil and heat it up good. If this gets things moving; back it out. Muscle it if you have too. The damage was done before you arrived. You might get lucky and the damn thing will give-up and come out.
    Phase Two: First "Drilling" proceedure. Using a seven sixty-fourths
    [ 7/64th's ] inch drill bit ... chucked into your Dremel Tool ... drill a small hole ... dead-center of the screw ... just deep enough to get a Number-2 Screw Extractor ... better known as an "Easy-Out" ... and make your first attempt to bring the Pilot Screw the hell out of there. Tap-in the Easy-Out to get it a good bite before you start backing it out. Yes? Celebrate a small victory! No?
    Phase Three: Just like Phase Two. Bump-up one size. Five thirty-seconds drill bit. [ 5/32nds ] Number-3 Easy-Out. You should be victorious. When oiled, heated and coaxed-out of there with the Phase Three approach ... there is still the possibility that the Pilot Screw can be brought back from the dead.
    Phase Four: Drill the Pilot Screw with progressively larger bits until there is just enough brass remaining to protect the Ultra-fine threading on the carb body from being damaged. Then, using a Dremel cutting tip score the brass length-wise at 12 O'Clock and 3 O'Clock and "Pick-out" the piece you scored for removal. Followed by Picking-out the larger section, too.
    Keep your eye on the prize.
    Job One!
    If you don't have a Dremel Tool, the right sized drill bits and the Screw Extractor set ... you will after you make sure your Credit Card is in your wallet and arrive back home, from Sears!
    Take a break. You deserve one.
    See you next time, on ...
    "The Old School Method"
    Your pal and Mentor,
    Rick Massey
    -30-
    *** "The Olive Oil Treatment" Developed by: Rick Massey 4.16.'76
  13. shamus
    shamus Member
    this is good.... has it been continued anywhere??
  14. RickCoMatic
    Thanks for the compliment. I can't find the draft of the closing of the piece.
    It was written during PRIME riding season. I guess now that riding season has all but ended, here in New England, I can wrap-up that article ... huh?
    Truth be told ... You are the only one who has come looking for it ... I guess. But, I own-up to being lazy about it. My bad.
    So, let's see ... where was I? Care to remind me?
    (I should also mention that I bought a YAMAHA DD55C Digital Drum Kit and rigged it to a 70 Watt PC 2.1 Speaker set-up. I've been downstairs doing my best Nigel Olsen and Liberty D'Vito impersonations to Elton John and Billy Joel's Greatest Hits when the coast is clear!)
  15. Flashgp
    Flashgp Member
    Indiana
    Rick,
    I am interested in the conclusion of this article as well. The end of riding season has me itching to get started getting her ready for next year.
  16. RickCoMatic
    OK ... I'll get on the stick and devote some time to wrapping-up the Carb Cleaning piece.
    I'm very happy to know those "Old School" articles have an audience. I started thinking there wasn't sufficient interest; what with Carb Clinic's and previous Posts concerning Pilot Screws and Mixture Settings.
    Anyone needing more specifics with overhauling Carbs can initiate a Forum Thread and I'll be sure to respond.
  17. shamus
    shamus Member
    The start of the thread is awesome...... then I was disappointed when I got to the end and it wasn;t continued!!!! top effort...
  18. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    I think a lot of us us here "attend your classes" and I think they´re "must read" if someone (like myself) is planning to pull and clean their carbs, maybe for the first time.
    I´m very much in favour of making a tech-section in this forum covering the various themes we´re all facing from time to time (petcock, carbs, brakes, forks etc.), preferably with pics supporting the texts - your writings would make a fine basis, I think. Others could chime in with comments/pics..
  19. RickCoMatic
    By: Rick Massey
    The Home Stretch:
    > Pilot Screws and Enrichment Valve Components and Removal
    > Clean-Tuning and re-assembly prep.
    As we round the far-turn and approach the Finish Line for Cleaning Our Own Carbs; these final few procedures are where you “Earn your Stripes” and do what is necessary to gain the very Maximum of Performance from the bike when we’ve done all the cleaning and “Clean-Tuning” steps necessary to allow the bike to run – “Perfectly!”
    We need to extract all four of the Pilot Jet Mixture Screws and their internal components. We also need to extract all four of the Enrichment Valve Assembly’s and springs.
    Then, with all the Jets and Internal parts removed; clean and blow-out the fuel and air passages before re-assembling the rack and tuning the Carbs to the very edge of their fine-tuning capability.
    > Removing the Pilot Mixture Screws and Component Parts:
    Because the Pilot Screw has such a very fine thread pitch they can be difficult (If not impossible) to move. Cleanliness is the key to their removal. The cleaner the area above their screw slots is; the easier they can be loosened and removed.
    As mentioned, many times before, use (or make) a tool that fits the slot with Watchmaker’s Precision. Keep the threads lubed-up with light machine oil. These are precision components. Handle with care.
    The hidden spring, washer and O-ring in the Pilot Screw housing are the tiniest parts on the bike. Take every precaution NOT to lose anything!
    Take the appropriate measures to work CLEAN, on a surface prepared for working clean and free of any place a small (Really, very small -- we're talkin' >Teenie-TINY<) part might fall into or disappear. Spreading some old bed sheet or linen beneath the work is a good idea.
    Each Pilot Screw must be withdrawn complete with its associated parts within the small chamber beneath the threaded head and stem of the Pilot Screw. Prepare for handling 4 (four), SMALL, easily-lost, precision parts:
    1. The Pilot Screw and Stem with its pinpoint Precision Metering Tip. (One piece.)
    2. Pilot Screw Tension Adjustment Holding Spring. (May come-out surrounding the stem on the screw. Might need to be lifted-out if it remains in the Carb body when the screw is lifted-out.)***
    Visually check bottom of spring for tiny flat washer.***
    3. Very, very, very-small Flat Washer. (Might be stuck to the lower end of the Spring or remain, in ... at the bottom of the housing needing to be extracted.)
    4. A very tiny O-ring. About the size of this letter >: “O” . The flat washer and O-ring are usually found at the bottom of the housing. They might be lifted-out when the spring is withdrawn > check spring.
    [My “Special Tool” for fishing-out the tiny Flat Washer and the O-ring from the bottom of the Pilot Screw housing is just a long “Safety-pin” that I heated and put a small angle on the tip.]
    > The Enrichment Valve Removal. (See! They're NOT Chokes)
    The Enrichment Valves come in a couple different flavors. There are Solid Brass Valves with a tapered seat end and a further narrow pointed shaft-pin seat; and there are some with a “Barrel-style Plunger” having a rubber seat attached to the base of it’s Barreled end, also-- shaft-pin ended.
    Removal:
    Remove the rubber dust cover. (Clean; let soak in Armoral)
    Loosen and unscrew the Hex-topped brass body.
    Remove the entire Valve, spring and brass body together. (Separate and clean individual components before re-assembly.)
    Once the Pilot Screws and Enrichment Valves are removed from the Carb Bodies, there are but a few “Air Jets” remaining in the Intake Port and beneath a screwed-on cover plate, where the rubber diaphragm seats; some models have an “Air Jet Cover” which needs to be removed to INSPECT these Jets. Other's have had the cover OMITTED at the Factory.
    Many others have had the cover OMITTED during maintenance.
    >> Note: There is a threaded opening for the special screw which serves to attach the cover if so equipped. If you are going to withdraw all the Air Jets for Air Passage cleaning ... MARK an "X" next to this threaded hole so it will not be confused as an Air Jet Passage.
    The Air Jets are all slotted and threaded for easy removal. But, since the openings in the center of the air jets are large enough to permit the Carb cleaner spray tip to shoot the air passages clean … you may (at your option) leave the Air Jets in place and spray and blow-out the passages without removing the Air Jets.
    If you MUST remove all the Air Jets, for dipping or sonic cleaning the Carb bodies … ID each Jet for > PROPER REPLACEMENT < Particularily the two Air Jets in the TOP cavity beneath the Diaphram Assembly!
    Certain Workshop Manuals show these Air Jets replaced> Incorrectly <!!! Following the illustration and placement shown in the HAYNES Manual will lead to a situation which REVERSES these two Jets ... making adjusting the correct air mixtures impossible without actually having the right sized air jet in the right place. A troubleshooting nightmare.
    If you are using a HAYNES Manual -- Do NOT extract the Air Jets from this area UNTIL you have:
    MARKED the Jets and Carb Body for ACCURACY -> AND made the appropriate CORRECTIONS to the incorrect HAYNES TEXT and ILLUSTRATIONS before the confusion results!
    > “Clean-tuning” the rack.
    "Clean-tuning" is the process of making the rack ready to accept all the cleaned component parts. There are a few very important “Clean-tuning” processes.
    1. The Diaphragm Assembly > “Clunk Test”.
    Please search and review the “Clunk Test” and necessary steps to prevent Diaphragm Assembly Sticking – or – “Stiction”.
    2. The “Sync Screws” and linkage.
    While you have the rack where you can access all the “Moving Parts” and make sure they move as they are supposed too. Loosen each Sync Screw and oil the threads on the screw and linkage. “Exercise” each of the THREE Sync Screws, IN and OUT, within their mount on the linkage, until you are satisfied that you have attained the ability to make precise adjustments to the Sync Screws without any binding or getting held-up by rust-dust or other oxidation.
    You have reached the Summit. You stand atop the peak you dared to assault. But, getting to the top is only half the story. Now, you reverse course and head back down to where it all began. It’s a joy to have cleaned your own Carbs. You have absolutely NO doubts about their cleanliness! So, don’t hurry the process of putting them all back together.
    Assembly is in the reverse order of taking them down and cleaning them … the Books and Manuals always say. If there were no major complications getting you along this far … the process of re-assembling your Carbs, hanging them back on the bike, firing-up the bike and doing the REAL fine tuning is just a matter of time.
    I’ll follow-up this articles with some “Do’s-‘n-don'ts and a few extra things to do to get your Carbs tuned-up better than they were, the day they were brand spanking new.
    That’s NEXT … after I get the feedback from what we’ve got on paper up to this point, here!
    Wishing each and every Member XJ-Bike Owner ... "High Performance" and
    Happy New Year!
    Rick Massey
    -30-
  20. Flashgp
    Flashgp Member
    Indiana
    Another excellent job Rick! I was going to do this job this weekend, but the weather has been too nice. I put another 50 miles on today :) Weather like this makes it hard to work on anything. Especially a bike that runs.
  21. RickCoMatic
    Happy New Year everyone.
    Welcome 2007!
    I managed to bang-out the information that brings-together the "Do Your Own Carbs" series; at long last. Because ... Winter is here!
    I'm going to be finishing-up the "Do Your Own Carbs" with a few extra added attractions; and watching the Thread in case there is any discussion or questions from anyone who might actually be diving-in and cleaning the heck out of their carbs for the coming season.
    I can appreciate how intimidating it is, for any "Carb-cleaning First-timer."
    I'll answer questions and everybody else will help you get 'em all back together and "On-the-hairy-edge" tuned-up.
    Clean. Clean-Tune. Re-clean after clean-tuning. Re-assemble with "High-performance touches." Bench-Sync. Mixture Pre-sets. Install. Cable-up.
    Button-up. Run. Tune. Race.
    You're on the way.
  22. shamus
    shamus Member
    With the air jets under eath the cover beneath the diaphram, Should the big or small jet be closest to the centre?
  23. RickCoMatic
    The Big Jet (#225) is forward.
    The Smaller Jet (#80) is "Center"
    The hole for the cover next. (Empty)
  24. Alive
    Alive Active Member
    Queensland, Australia
    Rick.... Excellent piece of writing and very useful to those of us who are working on carbs...
    Thanks :D
  25. shamus
    shamus Member
    thanks... thats exactly what it says in my Haynes manual....
  26. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    You could always do like I did. I went to star-motorcycles.com/service and printed out the pic of the exploded carb. as a referance.
  27. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Also, has anyone heard of cleaning your carbs by boiling them out in lemon juice? Yes, and there are alot of people who swear by it. I have not had the chance to try this method myself, but when the time comes, I will. It is not suppose to hurt any of the internal parts, so why not give it a try. It's suppose to work boiling the carbs for 1/2 hour, submerged entirely in the lemon juice. Just a thought! >PD<
  28. Dispatcher
    Dispatcher Member
    New York, USA
    An absolute "must read" for anyone who works on their XJ's. Thanks Rick! BTW, have fun with the kit. I saw where you had posted for info on the blog, but I thought you were going acoustic. I remember years ago wanting a set of Simmons, but I ended up with Tama Imperialstars. Nowadays, all my beats are done on the PC. There's some amazing software out there!
  29. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    Thanks for the info on the carbs, I bought some new intake boots to replace my old cracked ones, now I have another reason to take them carbs off.
    Now all I need to do is finish up my house remodeling and work on my bike.
  30. Fongdingo
    Fongdingo Member
    Charlottesville VA
    This is gerat, but how bout some pics to go along with it. Evreyone enjoys pics. I know get the cd Whish i could no pay pal acount.
  31. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Rick, this is an awesome bit of writing. If there were pix to go along with it it would be twice as good. This needs to have a new topic column opened for it and be permanently stored for others to view (C'mon, moderators..TechSection thread!!!!) Well done!
    How does this thread relate to the Mikunis?
  32. RickCoMatic
    There are a few "Different Looks" with Mikuni's. Nothing big.
    I agree that Photos will add a great deal to the text. I regret not having taken photos when I had the Carb Clinic.
    We had to drill-out a Mixture Screw on Wolfmajor's Carbs ... and, I had to drill and pull-out all the Plugs before I could get to mine.
    I have a set of Carbs down on my bench that I have to clean. I'll be getting to them as soon as the work to a Mrs. Massey's family-room project is done.
    I have one pulled one float bowl to se what I'll be dealing with. The "Ugly" is below all the floats and jets.
    So, those pictures are coming soon,
    BUT ... following the CRASH of my DELL ... I'm stuck with having ONLY typing until we get a NEW PC or a NEW MAC.
    I want a MAC
    Mrs Rick wants a PC
    Until we're done with that Tug-O-War ... I type in a font I can hardly read.
  33. RickCoMatic
    I have pulled one float bowl to see what I'll be dealing with. The "Ugly" is below all the floats and jets.
    I want a MAC
    Mrs Rick wants a PC
  34. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Get the mac although i use pc i wish i had a mac. The misses will like it once she gets used to it and will never go back once she does. Mac has better pic movie and publishing software, and no virus or crashing. hope to see the pics soon
  35. escali
    escali Member
    Virginia
    You need to make a "How to Clean Carbs for Dumbasses" manual, because it takes me longer to figure out what the pieces you are talking about are than how to remove them. Maybe a picture book for visual learners like me.
  36. RickCoMatic
    I didn't have a Computer that would deal with Photos all that too well when I wrote it. But, I do plan on taking my Carbs off the Bike and doing a complete "Show and tell" this off-season ... which ain't OFF yet!
    That and Guide to tweaking for Performance.
    I should have saved some of the photos I took of some of the Carbs I did for a few people during the season. I really had to pull out all the stops a couple of times.
    Rebuilt a Float Hinge Pillar.
    Drilled-out a few Pilot Mixtuure Screws.
    Put a new Hat on an Enrichment Valve Stem.
    Shoveled-out the crap on a set that sat for over 10-Years. (Nasty)
    What I really ought to do ... Now,, that I have this new MAC with iMovie ... is mic myself and do a Video of the Process from Beginning to End and make an affordable DVD.
    THEN we'll have some Clean Carbs on-the-street. Huh???
  37. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Hey I would buy it :)
    The pics add a bit of personality to the carbs.
    Instead of "that thingy next to the other thingy."
    Most of the ones who need this info are a bit behind the curve.
    Maybe a Pop Up Book, lol :lol:
    Great job BTW, I wish I could print it for the "John Reading"
  38. joshua
    joshua Member
    Lake Worth
