Cleaning the YICS channel
Discussion in 'Hangout Lounge' started by tabaka45, Mar 19, 2013.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    How is the best way to clean the YICS system without clogging the small openings?
  2. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    i ordered the wire brush from chacal and the special pick they have (works amazingly!) put a rag on one end, then sprayed a little carb cleaner in there and on the brush and just worked it in and out, its a tight fit so i used pliers on the end of the brush to get it in and out, run the brush threw several times. continuing with carb cleaner, then finish with air.
    brush is great quality BTW, doesnt break off little wires inside the passage
  3. quebecois59
    Is this brush to clean the YICS chamber or to clean every of the four small passages?
  4. Foolber
    Foolber Member
    for the chamber, and pick is what is for cleaning the passages
  5. schmuckaholic
    California
    Yet another shameless plug...
    The writeup for Len's YICS tool (The HCP5460 YICS Tool) shows the brush and pick.
  6. Orange-n-Black
    Memphis Area
    I just used the wire brush 410 bore cleaner out of my shotgun cleaning kit.
  7. tabaka45
    Brunswick, Georgia
    It would seem to me that it would be possible to actually push crud further into the passages with the pic.
  8. quebecois59
    The way I understand it, the crud you're talking about is most likely carbon build-up that would be burned in a flash in the combustion chamber and would do no harm.
    I'm more concerned about small o-rings Polock mentioned, I don't know where they are located, haven't seen them in any drawing yet.
  9. 750E-II_29Rbloke
    South Cheshire, UK
    I think the O-rings go between the head & block, surrounding the passageways? I haven't really looked that closely at my parts book but I'll have a goosey-gander in a second...
  10. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Go to a Gun shop and buy a brass 12 guage bore cleaning brush, you can also get a 12 guage swab and put a little oil on it to run through after and clean out the lose crud. That's what I use. Its the sort of thing that you can get local and with out the extra cost of shipping. And it works GREAT.
  11. quebecois59
    One recommends 410, the other 12, there is a pretty big difference in size. Isn't there 16 and 20 guage between 12 and 410?
  12. Foolber
    Foolber Member
    it would be a 410....i own all those sizes, but i wont use it on my bike. thats just me though.
  13. Polock
    The 410 is just that .410 inch the 12 ha is about the size of a US dime, the brushs are slightly bigger . That oring is about 10mm, you can't reach it with a pick or probe
  14. Orange-n-Black
    Memphis Area
    I used the 410 brush because it's just slightly bigger that the passage. I would think that a 12 would require more force and I need it to clean my shotgun, I don't own a 410.
  15. RickCoMatic
    A Small Bore Cleaning Kit from Army~Navy Surplus is $9.95.
    The easiest way to clean-out the YICS Passage is to employ the "Minuteman" method. The Minutemen were armed with Muskets. They had to load powder, push-in wadding and then push-down a lead round to load the thing.
    Pulling out a page from history ... use this technique to clean-out the YICS Passage.
    Simple to do.
    Remove the Hex-plugs from BOTH sides.
    Saturate small sections of Terry-cloth, ball-it-up and shove it in one side of the passage.
    (Sacrifice a pair of White Athletic Sock)
    Using a Wooden or Fiberglass dowel as a Ram Rod ... shove a soaked patch right straight through the passage until it falls-out the other side on to the floor.
    Examine the wadding you just fired out the other side of the engine.
    Black, ugly-looking, nasty with carbon build-up??? Sure will be.
    Repeat the process until you get one falling-out the other side, as clean as it was when you loaded-it in!!!
    Once its Clean:
    Tape the Carb Cleaner Red Tube to your Thumb.
    Stick the end of the Tube in the Passage and Seal the opening of the Passage with your Thumb.
    Idle the Bike.
    Squirt shots of Carb Cleaner into the Passage.
    The Bike will rev-higher as you shoot Carb Cleaner into the Passage you Cleaned-out.
    VanDutch likes this.
  16. quebecois59
    Thanks for the tip, Rick. What are we supposed to saturate the Terry-cloth with? Marvel mystery oil? Carb cleaner?
  17. RickCoMatic
    Carb Cleaner.
    Some guys just use gasoline. (It stinks-up the place).
    My Ramrod is a one-meter length of Fiberglass Driveway Marker Pole.
    I use the Rubber-end of a Craftsman (Dual) >Rubber//Hard Plastic<< Hammer to drive the Patch through the chamber.
  18. k-moe
    Rick, you're taking the fun out of it. Open breech, no powder, no projectile :lol:
  19. bigfitz52
    Interesting.
    My YICS passages never seem to be carboned up; the opposite is generally true; they're smooth and white with some gentle white deposits if anything at all. They're on the intake side; when combustion occurs, they are behind CLOSED intake valves.
    If you've got gummy, blackened YICS passages, then something is amiss; like I said, they're on the INTAKE side. Generally the stuff going INTO the motor is clean; or supposed to be.
    Black carbon in the YICS passage would tend to indicate a leaky valve stem seal on at least one of the intake valves.
  20. quebecois59
    What do you think these "gentle" white deposits are?
