clear finish restoration
Discussion in 'XJ Technical Chat' started by zoooooot, Mar 30, 2010.
  1. zoooooot
    zoooooot Member
    cleveland
    what gets this stuff off aluminum engine covers?
  2. Galamb
    Galamb Member
    Acton, Ontario
    zoooooot
    get some Aircraft aluminum stripper. Do it outside.
  3. TIMEtoRIDE
    What's the recommended clear coat (brand) to put back on for durability against yellowing right away ?
    What grit of paper reproduces the factory "brushed" finish?
  4. Galamb
    Galamb Member
    Acton, Ontario
    TIMEtoRIDE
    I kept the clear coat off, it only turns yellow again. Once in a while just polish it with Mothers.
    With the factory brushed finish, you can start off with 400, then 800 and up. And when you finally get it all off, Jewelers rouge (I used the white one) to buff it with.
    That brushed factory finish, is sometimes better just lightly sanded. Lot of work to get it to shine like mirror.
