Clip on bars
Discussion in 'XJ Technical Chat' started by vlopez83, Mar 3, 2015.
  1. vlopez83
    vlopez83 Member
    california
    hi I have a 1983 xj750 seca and I'm looking to put clip on bars just don't know what size to get
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
  3. razz1969
    razz1969 Active Member
    Cleveland, Tx
  4. razz1969
    Cleveland, Tx
  5. FtUp
    pacific northwest
    the op's 750 has 36mm forks.
    FU
  6. razz1969
    Cleveland, Tx
    I stand corrected. (it was and still to cold and wet to go outside to measure them, so I was going off of memory, but that's a whole other topic :)
  7. FtUp
    pacific northwest
    the xj550 seca's got 35mm tubes but the 550 maxim's got 36mm tubes and a longer head tube.
    edit; my bad, the head tubes on the 550 maxims and secas are the same length. but the upper tube diameter is still 36 and 35mm respectively.
    FU
  8. vlopez83
    vlopez83 Member
    california
    For the clutch and brake levers the master is in a tight spot in between the bars how can I switch it out to work on the the lever
  9. razz1969
    Cleveland, Tx
    please clarify
  10. Polock
    i have a suzuki with clip-ons and i just bought bars to replace them. nobody is ever happy :)
  11. vlopez83
    vlopez83 Member
    california
    Srry to change the subject but does anyone know the process to lower the front end of the bike
  12. Brandon Barnhart
    Brandon Barnhart New Member
    Indianapolis
    Do they match upthe factory brake line and banjo bolt? Wondering if application will work on my xj550 seca
  13. hogfiddles
    Take the front wheel off.
  14. Manny Mercado
    Manny Mercado New Member
    Seattle
    bringing this one back to life, I am looking to do the same thing (install clip on bars) on an XJ750 Seca and noticed that there isn't much space at the top of the fork, so it would have to go below the triple tree clamp. Reading through the maintenance documents it seems that the forks need to be depressurized for the clip on bars to go below the triple tree. Can anyone confirm if this is correct?
    similar to the way it is done on this video
  15. Simmy
    hogfiddles likes this.
