Clubman mounts???
Discussion in 'XJ Modifications' started by ST0CKM0NK3Y, Sep 16, 2010.
  1. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    I just ordered clubmans for my 82 xj750. and i cant mount them because the original bars were the two piece aluminum arms.. anyone know where to get the brackets that bolt to the top of the fork so my clubmans can be used? thanks guys.
  2. pauluminous
    pauluminous Member
    Vancouver, BC
    Doesn't that whole pile of sh.t come off leaving holes for risers?
  3. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    yeah, i just need to know where to get the risers.. haha do you know?
  4. pauluminous
    pauluminous Member
    Vancouver, BC
    Part #15 should leave holes
    U should be able to put in something like:
    Clubmans prolly go better with less rise, you shouldn't have no prob finding some on fleabay for about $10
  5. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    OH!! i see know, thanks man! hahaha i did see those before.. i guess i didnt know what i was lookin for.
  6. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Ok, so i ended up making some at my work out of some very random peices of hardware. Good news is theyre strong as hell and only cost me $20 (as compared to $50-$160) they also keep the clubmans low to the forks which looks awesome.
  7. ScreamingGigabyte
    ScreamingGigabyte Member
    Lake Charles, LA
    Pics please? I'm still debating on Clubmans or keeping the straight bar on the 4" riser and putting a headlight fairing on it (like in SoA)
  8. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    [​IMG][/img]
    [​IMG][/img]
    Basically its a split clamp that i took the allen screws out of (they were 1/4-20 thread) and ran two longer bolts from under the plate into the clamp. I had to use spacers to push it up off the plate. I also used the same spacers to fill the gap inside the plate. (because the holes are 3/8 in the plate) if you need a diagram ill try to draw one for you. haha
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Looks good, but is it strong enough for the long haul?
  10. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    I havent ridden it yet but i used grade 8 bolts and washers and the clamps are solid steel. If i had to put money on it (and in this case my life) i would. theyre real sturdy though. I wont have the bike in running order for awhile but ill make sure i update on how they hold up.
