Clutch help :/
Discussion in 'XJ Technical Chat' started by Trvpstar, Aug 22, 2019.
  1. Trvpstar
    Trvpstar Member
    Nj
    So I just replaced the clutch and put everything back in as it was and when I try to adjust my clutch cable towards the clutch side it just won’t snap back? Am I missing something here literally everything went back inside as it came out on the inside ..
    Pic for what I’m talking about
  2. Trvpstar
    Trvpstar Member
    Nj
    Pulling the clutch lever and it just stays sunk down
  3. Jetfixer
    Something does not look right to me you look like your missing the bracket here is what my 750 Seca looks like
  4. Trvpstar
    Trvpstar Member
    Nj
    I have a 550 and the only bracket I took off I put back on and even tightened the cable and still nothing
  5. Trvpstar
    Trvpstar Member
    Nj
    The clutch just doesn’t want to retract back for some reason
  6. k-moe
  7. Trvpstar
    Trvpstar Member
    Nj
  8. Trvpstar
    Trvpstar Member
    Nj
    Took this thing apart, re mounted the clutch and bolted back up and still no friction with clutch cable... I just pull it and it stays pulled and gets slack back and forth I haven’t even re adjusted the main adjustment of the cable, left it the same.. could it be my cable is done ? I find it hard to believe since I just unclipped it and that’s it.. someone, anyone pls give some input
  9. mlew
    mlew Well-Known Member
    Apex, NC
    Did you have to take off the crank arm to replace the clutch? Is it possible it is in the wrong position.
    Some close up pics of the clutch plates and springs might be helpful.
  10. XJ550H
    when you pull the clutck the lever does not go back when released? when was the last time you lubed the cable ?
    do you have 3 mm play in the lever where it hits perch?
    did you loosen cable at perch before installing it back on cover lever?
    where there any burrs on clutch basket?
  11. XJ550H
    does clutch release and let wheel freespin when in gear when lever is squeezed?
    did you aline dot on pressure plate with dot on basket?
    did you turn the cover lever fully forward before attaching cable? like photo with thumb .
    to the point that lever will not go anymore ? .
    new springs and bolts?
    soak clutch in oil before installing?
    tightening bolts in criss cross pattern equally until final torque of bolts?
