Clutch kills bike? 82 xj650
Discussion in 'XJ Technical Chat' started by Killerkhezu, May 29, 2017.
  1. Killerkhezu
    Killerkhezu New Member
    Minnesota
    Every once in awhile in neutral when I engage the clutch it will kill the bike. Giving it a little gas or even out to g it in first then back to neutral fixes this. Any ideas?
    try disconnecting your clutch safety switch in the head light bucket green connector.
    switch could be failing.
    Killerkhezu likes this.
  3. XJ550H
    just unpluging the switch will make it so your bike will only start in neutral.
    jumping across the connector will make it so your bike will start in gear. remember to pull in the clutch
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Mine does that when it is time to clean the safety switch on the side stand. If it happens, reaching down and wiggling/pulling the side stand safety switch with the kickstand up will get it to start. I have to clean the switch every few seasons, but it still sticks once in a while.
  5. XJ550H
    you can also remove the sidestand safety relay to test the circuit
    maxim location
    1982-84 Sidestand (kickstand) relay (blue): frame bracket outbound of LH frame tube, just behind the left ignition coil.
    82 seca location
    sidestand (kickstand) relay (blue): behind the flasher relay, under the front of the tank.
    turbo
    sidestand (kickstand) relay (blue): mounted onto a tab bracket welded to the right frame down tube, below the airbox.
  6. cgutz
    SE South Dakota
    I was giving him a "quick" solution to use in a parking lot so he could get started and on the road :)
  7. XJ550H
    I am thinking after the sidestand test he may need a new neutral switch
