Clutch Noise
Discussion in 'XJ Technical Chat' started by bluejay274, Apr 29, 2009.
  1. bluejay274
    bluejay274 New Member
    Hopkins, MN
    This last week I took apart my clutch enought to replace the friction plates and the springs. The disks looked fine to me so I reused those. I put everything back together and changed the oil including the filter. Re-filled and adjusted the clutch cable to what it was before. It still needs a bit of adjustment, but it does shift through all of the gears.
    The problem is since replacing the clutch parts the bike has started to make a higher pitched noise, but only when the clutch is engaged. When it is dis-engaged the noise immediatley goes away. I did soak the friction plates in oil for about 30 minutes before I put them in and believe that everything is back in place. It didn't make the noise before I replaced the parts.
    Any help or ideas would be appreciated. The bike is an '81 Seca 750 with about 18000 miles.
    Thanks.
