clutch slip
Discussion in 'Other Motorcycles' started by crapmuncher17, Mar 20, 2009.
  1. crapmuncher17
    crapmuncher17 New Member
    Salem, OR
    I have a 79 xs750 special that i bought a few months ago. i really opened it up today and the clutch was slipping at high RPM... and ideas why? Thanks in advance.
  2. alaskazzr
    alaskazzr Member
    Anchorage Alaska
    Oil, clutch plates, clutch cable. Not nec. in that order.
    - What kind of oil is in it?
    - What is the condition of the clutch plates?
    - Have you tried adjusting the clutch cable in at all?
  3. bigfitz52
    You might simply pull the clutch apart and CLEAN everything. You may find that it was just gummed up from sitting, or it could be time for some new friction plates. Don't "slip it" too much or you'll cook the drive (plain) plates and up the price tag on the rebuild.
  4. mlew
    mlew Well-Known Member
    Apex, NC
    Its always a good idea to change the clutch springs when inspecting. Springs do wear out over time, especially after 30 years. I bet they are a little weak.
