Clutch slipping
Discussion in 'XJ Technical Chat' started by ronha13, Aug 19, 2013.
  1. ronha13
    ronha13 Member
    Curtiss Wisconsin
    I guess I need to replace my clutch plates.
    Do I need to buy the tool described to replace these, or can it be done without it?
    The tool costs more than the plates lol
    Thanks in advance for any info :)
    1985 Maxin xj700
    34,000 miles
    just replaced valve shims about a month ago
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Gonna need a new clutch cover gasket and thats about it.
    New springs, new bolts, new Friction Plates.
    That should just about do it. You WILL need a torque wrench though. I think it was like.. 9lbs?
  3. mlew
    mlew Well-Known Member
    Apex, NC
    No you don't need the special tool, its only needed to remove the inner part of the clutch basket. You only need to remove the outer to replace the clutch plates.
    Definetly get new springs when installing new friction plates. They are the cause of most clutch slippage problems.
  4. bigfitz52
    Give this a read: http://xjbikes.com/Forums/viewtopic/t=29541.html
    Your clutch will be simpler; you don't have asymmetric, "tabbed" plain plates or a special friction disc/clutch boss spring to worry about, yours is just steel plates and friction plates. All the other principles and procedures are the same.
  5. Wirehairs
    Wirehairs Member
    St. Paul, MN
    On a related topic (not hijacking the tread here!), could someone tell me the usual symptoms that tell a person that it's time to replace their clutch? Is it just basic slipping when shifting that gradually gets worse and worse?
    I saw a Maxim 400 for sale that said the clutch was starting to slip, and I just don't want to mistake something worse for a simple clutch plate replacement.
  6. bigfitz52
    Pretty much. You don't usually notice it at first while shifting; what generally happens is that when you hit the powerband it will slip then re-engage, often well after shifting into whatever gear you're in.
    It will show up when shifting, sure; but it will usually have been giving "clues" beforehand.
    Also, generally speaking, it's usually just a case of an original clutch needing to be rebuilt (friction plates & springs.) Excessive wear/damage to the hub and/or basket usually only shows up in relatively high-mileage bikes.
  7. ronha13
    ronha13 Member
    Curtiss Wisconsin
    Awesome, thanks for all the info.
    Its nice to have experienced help a few clicks on the keyboard away :)
    Another quick question...
    What brand should I buy?
    From what I can tell, the price is anywhere from 35.00 for EBC Heavy Duty to 120.00 for Barnett Kevlar friction Plates... ??
    Is there that much of a difference in them?
    Ron
  8. bigfitz52
    Only if you're planning on going racing.
    Aftermarket friction plates (EBC, K & L, etc) are fine, the brand-names are usually better than stock anyway. I'd avoid no-name eBay stuff.
    You'll need to take Scotchbrite to the plain plates and get rid of the "memories" of the old friction plates; but as long as they aren't burnt blue or warped they can be re-used.
    REPLACE the springs AND BOLTS. Get real bolts, from XJ4Ever or from Yamaha, not from the hardware store.
    Be sure to soak all of the new parts in oil beforehand, especially the friction plates.
    Most importantly, take your time and be patient and careful.
  9. ronha13
    ronha13 Member
    Curtiss Wisconsin
    am gonna get them from XJ4Ever :)
  10. ronha13
    ronha13 Member
    Curtiss Wisconsin
    1985 xj700 air head.
    Do I need the secondary friction plate, or just 8 primary friction plates?
    Im thinking of going with the after market high performance ones.
    Is this what I need?
    7 primary friction plates
    1 secondary friction plate
    6 springs
    6 bolts
    6 washers
    clutch cover gasket
  11. bigfitz52
    Check with chacal I don't think your clutch uses the secondary friction plate.
  12. ronha13
    ronha13 Member
    Curtiss Wisconsin
    from what I can figure out, the secondary is needed if I get the high performace after market set.
    with the regular OEM it say secondary isnt needed but with high performance ones it is...
    unless Im misunderstanding what it says???
    Wouldn't be the first time I was wrong lol
  13. bigfitz52
    SEND THE MAN A PM.
    Or an email. You have to do that to order from him anyway. He'll ensure you get the correct parts.
  14. ronha13
    ronha13 Member
    Curtiss Wisconsin
    I sent him a pm and am waiting for a reply :)
    I worked all night.. 12 hours.
    And my brain is about fried - think I better get some sleep lol
  15. nycxj750
    nycxj750 Member
    New York
    Chacal is great for orders. specially if you are not sure what you need or its a hard to find part.
  16. adrian1
    adrian1 Active Member
    Whats more, you KNOW you'll get the correct parts.
  17. nycxj750
    nycxj750 Member
    New York
    Since this seems to be the post about clutch issues...
    How often should you lubricate the cable... and can you used WD40 or does it have to be something specifically for clutch cable?
  18. bigfitz52
    I lubricate all my cables once a year at the beginning of the riding season.
    DO NOT USE WD40. It is NOT a lubricant, it is made for displacing water. It will gum up when exposed to the heat from the motor and can cause a sticky, binding cable.
    You want to use a good quality (auto parts or industrial, not hardware-store) high-temp capable lube or even motor oil.
    I use Tri-Flow (spray) myself, with a cable-luber.
  19. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    I got a cable lube tool this year, and I can't believe I went all these years without this $5 device..or that I wasn't around when Fitz was given his.
  20. nycxj750
    nycxj750 Member
    New York
    I got the luber tool... just need to get the lube spray now.
    Bigfitz52 you use the Tri-Flow (spray on your, choke, clutch and break cables?
    What do you use if you do use anything on Tach cable?
  21. bigfitz52
    Yes, Tri-Flow for control cables.
    Tach cable gets motor oil (because it is in actual contact with the cylinder head it gets even hotter at the one end.)
    I generally use Tri-Flow in the speedo cable too, but with a dollop of grease at the bottom end. (Motor oil works fine in the speedo cable too.)
