clutch
Discussion in 'XJ Technical Chat' started by roger72, Apr 19, 2011.
  1. roger72
    roger72 New Member
    New Jersey
    I have an 85 xj700 and im replacing the clutch. Is it normal that the clutch basket has alittle play in it? any help would be great. Thanks in advance.
  2. bigfitz52
    Define "play." Some in the right direction is fine. You didn't give us much to go on.
  3. roger72
    roger72 New Member
    New Jersey
    in and out and side to side a little bit.
  4. bigfitz52
    Once again, not a lot of info but OK.
    You will have a little bit of in/out play; probably 1-2 mm or less.
    The basket itself does have a small amount of "wobble" play; whereas the hub shouldn't have any, just a minimal amount of in/out play.
    Hope this helps; take a look in the book or at the exploded view in my clutch article, and see how the basket is supported only by a plain bushing at the rear, it's kind of just "floating" there. So it will have a bit more play compared to the hub, which is firmly attached to the shaft.
