Coil not firing.
Discussion in 'XJ Technical Chat' started by roninn, Sep 21, 2012.
  1. roninn
    roninn New Member
    Nowhere
    Ok, I got an '82 xj1100. firing on 2 and 3, but not on 1 and 4. coil is good, switched everything and it goes fine. Ignition unit checks out. is there something im missing? or do i need to strip off the tape and look for broken wires?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Multimeter FTW! Get the wiring diagram out and check the continuity of the wires back to the TCI.
    Then it would normally be the crimps on the ends where any OCs occur.
    Of course if there is no OCs then you probably have a bad TCI or bad pickup coil or...
  3. roninn
    roninn New Member
    Nowhere
    What are the chances that the tci box has failed? And is there a good way to test it?
  4. danielcarver47
    danielcarver47 Member
    carolina borders
    X2 its a bad wire somewhere, very unlikely that the tci failed on one channel, you could find out easily by switching the coil plugs but i think its a failed connection
  5. roninn
    roninn New Member
    Nowhere
    Ok. wires all check out. Come to find out, the previous owner was a electrical engineer and may have repaired the TCI once. FML
