colortune mishap
Discussion in 'XJ Technical Chat' started by wingnut63, May 15, 2012.
  1. wingnut63
    wingnut63 New Member
    using colortune i worked as it should nice blue flame !!!!cool ...next few day cleaned carbs on 2nd bike and using colortune blew out the glass...when they say dont rev your bike its no joke...50 bucks lession learned...but i was wondering can't just bip it alittle after adjustments? or not at all...one thing to the colortune was an old 500 type from the 70s
  2. MisterShah
    MisterShah Member
    Tucson, AZ
    Probably has something to do with it. I have seen a colortune used, engine revved, and no problems. Not saying it's a great idea...just saying. 8)
  3. MrPhys
    MrPhys Member
    Knightdale, NC
    Here's the thing. That glass will blow out at a certain maintained psi. If you know anything about electronics, it's very similar (in fact it's the analog equivalent) to a diode, or more specifically a LED.
    LED's can be much brighter if flashed very quickly utilizing their peak current for short bursts, after which the led electrodes dissipate heat and cool just enough to be pushed to their limit again. If you flash it too fast even within it's peak limitations, the LED won't recover, it will just burn out.
    This relates, I promise.
    When you rev your engine, you're increasing (of course) your RPM's, which means the weakest point on the colortune plug isn't being given enough time to recover. Some may never have a problem rock'n out at 10k for 5 min, some will go if you just bip it. It's just one of those things, it will stand idle pressures for tuning... otherwise everyone would just run colortune plugs all the time (if you're cool spending $50 a plug that is).
    By the way, my first colotune plug for my first project bike (second bike ever) arrives Fri.
