Compatible years for 1982 xj750
Discussion in 'XJ Modifications' started by Nomad1956, Mar 17, 2014.
  1. Nomad1956
    Nomad1956 New Member
    USA
    Hello everybody. Just bought a 1982 xj750 and was curious what other years the exhaust might be compatible with, if any? Or if anyone knows of a source for cross referencing parts with this year?
  2. CapnRedbeard
    CapnRedbeard Member
    London England
    Could try searching for the xj cd, it contains plenty of info and only costs a couple of dollars for you on your side of the pond.
  3. Nomad1956
    USA
    Thank you Capn!
    I know the 81-83 XJ750 Seca exhaust is the same. I also know that the 82 XJ650 Seca exhaust will fit a 750 (that's what I'm running on mine).
  5. TIMEtoRIDE
    From the head to the "belly mount" point, the 650's and 750's seem to interchange (Seca or Maxim) but the muffler hanger location will/may need a short strap fabricated.
    From a performance standpoint, the 650 Maxim exhaust may be more restrictive. It had smaller cam specs. than a 750.
    The 700's might also fit as above, but I don't know.
    The 550's, 600's and 1100's won't fit.
    Any reasonably shaped muffler, from anything, can be adapted to fit with a welded bit of pipe, and a strap. Including tractor mufflers, Harley Sportster throw-aways, and other bikes.
  6. Nomad1956
    USA
    Thanks guys I'm starting to realize there are actually several options.
  7. bigfitz52
    Pretty much all of the USA-market 750s, '81 ~'83 Seca or Maxim, had the same exhaust system except for the mufflers.
