Compensating for different jet height.
Discussion in 'XJ Technical Chat' started by Bobby7711, Feb 26, 2015.
  1. Bobby7711
    Bobby7711 New Member
    Merrill, MI
    I recently bought my second maxim, and it is my first 1100. It ran when i bought it but needed its fix of ether to fire. So i did what we all do, i waited till the snow started flying, and pulled my carbs. I gave them the typical once over, being sure not to miss any enrichment circuit as i suspected that as my problem. Once i removed the float bowls i noticed one of my main jets was lower than the rest. Upon inspection i realized i was missing a spacer. Once i removed the jet i found why. The threads on the jet were broken and wouldnt grab with the spacer in place. Can i adjust float height to compensate or am i bound for a jet kit?
  2. Bobby7711
    Merrill, MI
    She still runs good 1/4 throttle and up.
  3. MiCarl
    That's not a spacer, it's a sealing washer. You should have it there.
    Pop for a new jet and washer (not a kit). XJ4EVER should be able to help you out.
    BTW, that is not the reason it is hard to start. It's likely starting hard because the starter jets (in the bottom of the bowl) are clogged. Your mention of it being great above 1/4 throttle leads me to believe it's not below 1/4 - that will be your idle (pilot) circuit. Do a proper cleaning while you're in there.
    jmilliken likes this.
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    welcome to the forum. pm chacal (supporting member here), he will sell you the jet and washer you need.
    FU
  5. k-moe
    Exactly that.
    http://www.xjbikes.com/forums/index.php?threads/in-the-church-of-clean.14692/
  6. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    I would suggest throttle shaft seals too. They are commonly neglected, and a source of major headaches too.
    Also goes without saying. Get your valve shims in spec too.
  7. Bobby7711
    Merrill, MI
    Thanks guys i will do that
