compression test results
Discussion in 'XJ Technical Chat' started by mmcgee, May 29, 2013.
  1. mmcgee
    mmcgee Member
    Just finished the compression test. Not good.
    1: 130psi
    2: 145
    3: 130
    4: 110
    The only one out of spec is 4, but they are all low. Now what?
    Also, took it for.a ride and it's back to its old problems. Nearly stalled going up hill with the throttle wide open. Backfired like 5 times. And the fuel valve is leaking. Again.
    Finished the Carb sync and now I'm right back where I began....very frustrated.
  2. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Try squirting a few shots of oil in each cylinder and re-checking. If compression comes up significantly, you have ring issues. If it stays the same, your problems are probably valve related.
