compression test
Discussion in 'XJ Technical Chat' started by mmcgee, May 27, 2013.
  1. mmcgee
    mmcgee Member
    Do I need to disconnect the igniter box before doing the the test? I seem to remember reading that somewhere...
  2. smokeater
    smokeater Member
    I just did a test on all four a few hours ago for the first time. I didnt disconnect anything and had no issues. I dont know if my results are skewed because of it but nothing went wrong. But my bike isnt running either
  3. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Geez, I hope not. Otherwise I fried mine years ago.... :wink:
  4. Captainkirk
    Captainkirk Member
    Northeast Illinois
    One thing to remember; with carbs mounted, compression test needs to be performed with the throttle wide open
  5. moellear
    moellear Member
    Lima, Ohio
    I've always disconnected it before doing the test, but only because Fitz suggested it. I'm not sure why either...
  6. bigfitz52
    Because you're not supposed to "light up" the TCI if there are no spark plugs (or you didn't ground the HT leads) as you risk cooking it.
    The manual(s) have you ground the plug wires. It's easier to just unplug the TCI.
