confused
Discussion in 'Hangout Lounge' started by RSpark, Jan 27, 2012.
  1. RSpark
    RSpark Member
    Dubuque, IA 52001
  2. bigfitz52
    It's not 100% right.
    The 550 Maxim was 3.4 gallons (13L) according to the Yamaha sales brochure I have here as well as the FSM; and the FSM for the 650 Maxim also lists 3.4 gal (13L.)
    This squares with Haynes; and they show the 750 Maxim at 4.5 gallons.
    I'm pretty sure that's correct; the 550/650 Max are the same, the 750 tank IS bigger.
  3. RSpark
    RSpark Member
    Dubuque, IA 52001
    Well I guess I still need to look for a 750 tank.
  4. bigfitz52
    It won't fit a 550 very well. WAY longer, it'd overhang your rear mount. Just because the 550 and 650 Maxims had the same fuel capacity doesn't mean a 550 and 650 tank are the same-same.
    While you can swap parts between 650s and 750s all day, none of the stuff is truly interchangeable with the 550s; it just looks the same.
