Conversion to a single brake line
Discussion in 'XJ Modifications' started by dan_betzing, Oct 31, 2010.
  1. dan_betzing
    dan_betzing New Member
    Philadelphia
    Anyone know why Yamaha designed the front brake system on the Maxims with a two brake line set up? Why did they put that fitting between the two lines? Im redoing the front brake set-up on my 81 chop and want to switch from the two line setup to a single steel braided set up. I just wanted to make sure the fitting didn't have any type of cooling feature or something that Im not seeing. Thanks
