convert my 81 seca xj750R to chain drive
Discussion in 'XJ Modifications' started by inlinefever, Oct 3, 2009.
  1. inlinefever
    inlinefever New Member
    Taft California
    I was told that u could ue the xj550 parts and swap them with the xj750. I was wondering if anyone has heard of this.
  2. joshua
    joshua Member
    Lake Worth
    why ruin a good thing? The shaft drive was intended for touring not racing.If u insist i guess u could try it but i despise having to buy chains every 6-9k miles. And my lst one the gear that turned the chain stripped off the spline,so i was purdy upset when the shop told me what it would cost to fix it. Lucky for me the guy had just changed my chain and i left only didnt get outta da parkin lot as it wouldnt drive. pushed it back around and he ripped her open to find a gear stripped off. LUCKY for me he had a thred file and saved the basket case for one more chain run. Got rid of it before i wore that one out. Since then i just love the shaft drives,even with the middle gear whine...........
  3. inlinefever
    Taft California
    Josha, do u have a problem with the bike horseing up on u.
  4. joshua
    joshua Member
    Lake Worth
    LOL,not anymore. stopped doin that stuff,reserved in my OLD AGE. but u go right ahead,youngsters heal faster than us old farts do!!!
  5. Polock
    i guess you could turn it into a Hayabusa if you used enough Hayabusa parts
  6. leadboots
    leadboots Member
    aylmer ontario canada
    I would really like to see this. Ive seen a xs 1100 switched to chain.
  7. TIMEtoRIDE
    Might as well add a kick starter while you're at it. It's a bolt-on,
    After you get new castings, bearings and custom made shafts.
    OK, no.
  8. organizedinsanity
    organizedinsanity Member
    To make a long story short, it is not practical to convert an xj 650, 700, 750, or 900 to chain drive. You would either have to swap engines with the 550 or other bike, or re-engineer the trans shaft and engine cases. Unlike the 1100, the other xj's have the middle drive unit actually made into the engine case.
    My maxim is now chain drive but I am not using the factory engine. If I were to start over I would just leave it shaft drive and buy another bike to mod.
  9. inlinefever
    Taft California
    thanks for all your in put guys. I think I will leave it a shaft drive cause i like the way it rides so why ruin a good thing.
