Cracked muffler
Discussion in 'XJ Technical Chat' started by minturn, Sep 1, 2008.
  1. minturn
    minturn Member
    colorado
    The patient is a 1981 XJ650. It has a broken muffler. The funnel shaped muffler has broken away from the pipe just behind the heat shield under the riders left heel.
    I can see cracks developing around the other side in the same place.
    Can this be welded back together (I'm not concerned about beauty)?
    What other options do I have?
    Jim
  2. schooter
    look for some new stock pipes and pray they are cheap, aka consult a junkyard.
  3. maz43
    maz43 Member
    Detroit area
    FWIW,
    Ebay has a stock left side muffler for your bike at the moment.
    I found a complete original exhaust in excellent shape on EBay for 150 bucks.
    Everything from the front pipe to the mufflers.
  4. bigfitz52
    eBay for sure. I put together a complete exhaust system for my Seca that way, just takes a little patience.
  5. Polock
    a good welder could fix it right up , but check out the mounts too if it's loose and vibrating it'll crack again, no fault of the welder
