crankshaft removal? and torque spec?
Discussion in 'XJ Technical Chat' started by stevo32, Mar 30, 2013.
  1. stevo32
    stevo32 Member
    sharon wi
    Helo guys i did order another repair manual but its coming from the uk so its gunna be awhile. At least two weeks. So i already have the parts and i wana ride. So i got the yamabond sealant crap, and the primary chain guide. I want to install it. It would seem that i must first remove the crankshft but what iam not sure off is the caM CHAIN. Does the cam chain have a master link on it or ist it like the primary and all one solid piece.
    Post script, does anybody kno wthe torque specs for all the bolts. :p :p
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i'm sure the knowlegable guys on here can help you, but they need to know which bike, and year
    stu
  3. wizard
    you can un-bolt the cam sprockets, you don't need to break the chain.
  4. stevo32
    stevo32 Member
    sharon wi
    sorry forgot its an 82/83 seca 750. r u sure i can just loosen the sprockets cuz it looks like there is some sort of masterlink on it but i think its a one time use only masterlink.
  5. stevo32
    stevo32 Member
    sharon wi
    k so i pulle a cam shaft out and that dropped the chain enough i think no lies in trying to get the starter clutch out. all i am doin is spinn the crank shaft prolly screwing up my timing is there any specific way to remove the starter clutch assembly?
  6. wizard
    Yes, you have to split the cases.
