CrankShaft seal leaking behind pickup coil plate...
Discussion in 'XJ Technical Chat' started by rpgoerlich, May 10, 2009.
  1. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Well, It's gotten worse.
    Looks like it should be able to be replaced from the outside.
    But the seal in all of the online diagrams, look to have a lip on the inside that would fit into a slot behind the seal.
    Len?
    BigFitz?
    Thanks,
  2. chacal
    You aren't going to like my answer...........
  3. dpawl31
    dpawl31 Member
    NH, USA
    Epoxy it man.
    lol jk...
    Looks like you need to get that answer from Chacal via PM, due to it's disgusting nature. :)
  4. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Then It's got to be something along the lines of splitting the cases Eh ?
  5. dpawl31
    dpawl31 Member
    NH, USA
    YEPPERS.
  6. Thee_oddball
    Thee_oddball Member
    sorry m8, just checked the manual///looks like a case split :(
  7. Robert
    I had a similar problem with my FZR (same lipped seal). I tore that seal out with a small screwdriver. The replacement I ended up with had no lip and was a press fit (quite snug at that). I used RTV to ensure at least some resistance to blow-out. 2000 miles later, no issues...yet.
  8. bigfitz52
    Replacing the original seal apparently will require a case split (didn't we discuss this already a while back?) -sorry-
    That being said, maybe Robert's solution has some merit? If it DOESN'T work, you'd have to split the cases anyway, and if it DOES, problem solved.
  9. Robert
    I'm hopeful too, splitting cases is a chore, one I try to avoid where and whenever possible.
  10. bill
    bill Active Member
    Raleigh, NC
    And the nominee for the understatement of the year is ....
    Sorry Robert couldn't resist. :D
  11. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    I got the numbers off of the seal. Going to try and find a replacement at our local bearing and seal provider.
    I was thinking I could pull out(most of) the old seal and press one back in from the outside. Sealing it in with some YamaBond.
  12. bigfitz52
    I would use some sort of hooked poky tool to make sure you get what's left of the old seal's trapped flange out so you don't have a disembodied rubber ring floating around your bottom end... it only appears to be trapped from one side.
    Sounds like a plan.
  13. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Well found a seal today. FYI an 82 XJ550 Maxim LH Crank seal is marked 32x45x7.3mm. All I was able to find was a 32x45x7mm.
    I drove a hole through the seal with a sharp punch. Tried to use a cheapo harbor freight seal puller with a 2x4 behind it, broke it as it was cast... :oops: Ended up using my screwdriver to pry out one end after cutting through the seal and worked it out without damaging anything! :D The flange is trapped on both sides. Cleaned up the opening and after buttering it up with some Yamabond drove the seal in with a large socket just until flush with the outside. Ran it for a while in the garage as it's raining and no leaks! 8O
    Thanks ALL!
  14. Thee_oddball
    Thee_oddball Member
    glad to hear it :) do keep and eye on it over the next month to make sure it is not leaking or working its way out
  15. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    After thinking about it, I went back out there and staked it in 2 spots just enough to keep it there.
  16. bigfitz52
    Sounds to me like it's fixed. That's a good one to know; as long as the seal is locked in place it should work fine long term.
    And you didn't have to split the cases. +1.
  17. rob_lit79
    rob_lit79 Member
    Wichita, Ks.
    Looks like this is a fix I need to try. I wonder how successful this fix has been.
  18. xyxj650
    xyxj650 Member
    Fergus Falls MN
    rpgoerlich
    Just wondering how your repair job was working? I am looking at doing the same thing.
