curiosity question... blinkers
Discussion in 'XJ Technical Chat' started by stereomind, Jul 3, 2007.
  1. stereomind
    stereomind Active Member
    Tulsa, OK
    ok, so I guess my 550 has self-canceling turning signals.
    What exactly makes them cancel? I've not been able to find a pattern.
  2. redcentre003
    redcentre003 Member
    The self cancelling unit is probably under the seat close to all the other elctrical thingies. Also, in the speedo housing is a small sensor and "theoretically" the cancelling of the indicators happens after you travel a certain distance or it is timed out.
    On my 900 it works both ways but not with any great predictability. Generally it is triggered by the distance covered - can't remember what that is - I think it's on an electrical info/help page for XJ's. The key to it working is the sensor in the speedo housing which can actually be removed and inspected if not working.
    Any other takers on this...?
  3. RickCoMatic
    Timed -- after so long they cancel
    Motion -- after so far they cancel
  4. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    According to my Seca's owners manual,
    "If the switch is not cancelled by hand it will self-cancel after the motorcycle has travelled about 10 seconds or approximately 150 meters (490 feet) which ever is greater."
  5. stereomind
    Tulsa, OK
    ahh... it all makes sense now :)
  6. Altus
    Altus Active Member
    London, Ontario
    The "cancelling unit" is actually a special flasher unit on our bikes, it works in conjunction with a magnetic reed switch in our speedometers that measures how far you've traveled with the flasher activated.
    The "timed" feature is actually non-existant -- it just depends on how fast you cover that set distance. Pretty sure it's set to 150 metres / yards.
  7. singlewm35
    singlewm35 New Member
    Carrollton, GA
    Altus is correct, per my manual for an 82' xj650j
    The signal will cancel in ~150M or 490ft
    It only works on motion and will not self-cancel while the bike is stopped.
  8. Maximator
    Maximator Member
    South Cariboo, B.C., Canada
    Ok, that helps understand the seemingly erratic behaviour.
    Mine take a bit to start flashing after I push the button, so I tend to start the signal sooner than I would in another vehicle. This of course means I often have the signals turn off before I'm ready when travelling on the highway. It's very distracting keeping an eye on your signal indicator (or resisting the urge to) while negotiating a turn in traffic.
    Is the delay before flashing starts normal for these bikes?
  9. blackdiscoball
    blackdiscoball Member
    dayton, Ohio
    Intresting, I didnt know they were self canceling. Ive noticed them shut off but like stereomind, couldnt figure out any rhyme or reason.
  10. singlewm35
    Carrollton, GA
    my bike has no delay before flashing, at least nothing noticeable
  11. Rasputin
    Rasputin Member
    Pennsylvania
    My bike also has no delay. I would be surprised if they were time cancelling; that wouldn't seem safe when sitting at a traffic light.
  12. Maximator
    Maximator Member
    No delay, hmm. Thanks for the feedback.
    I guess I'll have to pull the tank and see if I missed any connectors when I was removing oxidation from the electrical system. I'm hoping it's just not getting quite as much power as it should and therefore takes a bit to get going. Sounds better (read: cheaper) than a weak flasher or cancellation relay.
  13. Altus
    Altus Active Member
    London, Ontario
    I'd suspect your signal switch might be the culprit actually - you might want to take it apart and give the contacts a good cleaning, and then protect with some dielectric grease.
    Either that, or your bulbs aren't drawing enough current to activate the flasher reliably....
  14. Maximator
    Maximator Member
    Thanks Altus. :)
