Custom Seat Attempt
Discussion in 'XJ Modifications' started by Kevin Erwin, Feb 26, 2016.
  1. Kevin Erwin
    Kevin Erwin New Member
    Vancouver BC
    Hello,
    I am trying to build a custom seat for my XJ650 seca and I was wondering if it is acceptable to drill 2 vertical holes in the cross bar part of the frame as seen in the picture? I want to drill the holes so that I have an easy mount for the seat but do not want to compromise the integrity of the frame.
    you could weld something to it instead? or u bolt a bracket.
    what size holes are you thinking?
  3. Kevin Erwin
    Vancouver BC
    I don't have regular access to a welder. I was thinking of using a bracket as another option. If I do drill, it would probably be 1/4" i think.
  4. XJ550H
    it should not be a problem considering if you were in any kind of impact that would cause failure you would have a lot more to worry about than the cross member failing.
    mnrider and Kevin Erwin like this.
  5. k-moe
    Make sure to do something to prevent rust from starting inside of the frame tubes.
    mnrider and Alan63 like this.
  6. Steve M.
    Steve M. Member
    Bedford co va
    Don't know what you are using for a seat Pan but
    u bolts facing down through the pan makes for an easy mount on that cross bar
  7. Kevin Erwin
    Vancouver BC
    Thanks, I am going with something similar to this idea
  8. AxeMatt
    AxeMatt New Member
    Drayton Valley
    Are you planning on sewing your own vinyl or leather? I'm planning to do my own seat as well and am wanting to know what thickness of leather is typically used as seat material? Any idea?
  9. Steve M.
    Steve M. Member
    Bedford co va
    Any furniture grade leather or marine grade vinyl will work.the vinyl will last longer in the weather.
