cylinder numbers
Discussion in 'XJ Technical Chat' started by dave cutlan, Feb 24, 2016.
  1. dave cutlan
    dave cutlan New Member
    bristol uk
    Hi guys and gals i am new here im dave and i am in bristol uk i have owned yamahas in the past an xj650 a 750 and 2 xj900 diversions, i have just acquired a xj750rl which i am told is quite a rare model which went mainly to canada. I bought this bike on ebay almost totaly dismantled. I have started my rebuild and i have my first question my ht leads are labeled 1-4 but which is number 1 cylinder is it as your sitting on the bike or viewed from the front. Hope someone can help. Cheers. Dave.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    if you're sitting on the bike and looking down at the engine number 1 cylinder is the left one
    stu
  3. dave cutlan
    bristol uk
    Cheers stu
  4. hogfiddles
    All xj's are numbered left-to-right as you're sitting on the bike.... 1 on the left, 4 on the right.
    Now to help you, your 750rl is indeed a precious find. You will find a lot of info available for the xj900 Seca, and that will be a big help to you--- the 750rl is basically an xj900 Seca but with a 750 in it instead. Virtually all parts interchange, very few exceptions.
  5. dave cutlan
    bristol uk
    Many thanks for your info perhaps i can pick your brain in the future. Cheers Dave.
  6. tjantunen
    tjantunen New Member
    Finland
    Old thread but I have a question regarding the numbering of the wires. As wires have nubmers 1,2,3,4 but firing order is 1-2-4-3, so in which order wires should be set? Are numbers on wires just representing cylinders not firing order?
  7. hogfiddles
    Wire get put on like this:
    when you are sitting on the bike,
    Number 1 is by your left knee
    Number 2 is next
    Number 3 is just to the right of center
    Number 4 is by your right knee
    One of the coils fires #1 and #4. The other coil fires #2 and #3
  8. tjantunen
    Finland
    ok, thanks for clarification. I got messed up when I started to think that should wires be set according to firing order not accroding to cylinder numbers.
    Like: one coil would control cylinders 1 and 3 and second coil would control cylinders 2 and 4
