Daytona bars, bolt on?
Discussion in 'XJ Technical Chat' started by FirmusArma, Dec 4, 2009.
  1. FirmusArma
    FirmusArma New Member
    AZ
    I'm wanting to get some new bars, found these mikesXS bars
    Part #25-0122 Daytona Tour Type Bar
    The question is, will they bolt right on without modification?
  2. bigfitz52
    onto what?
  3. FirmusArma
    AZ
    sorry! forgot to include my bike info in the signature!
  4. dwcopple
    dwcopple Active Member
    bay city, michigan
    yessir
  5. bigfitz52
    Yes; however you will need to re-route your cables and possibly change the angle of the brake hose at the M/C. I think on the bigger bikes you can "route out" the extra clutch cable length.
    On my 550 Secas with the "Euro" bend, I had to go to a shorter clutch cable, everything else "tucked" ok. I also went to a shorter upper brake hose, primarily for appearance.
  6. jhicks13
    jhicks13 Member
    Toronto, ON, Canada
    It should be a straight swap. I put Daytona's onto my 550 Seca and with a little re-routing and adjusting, everything worked out great. Upper brake hose could be shorter but works fine and I moved the throw arm on my clutch back a notch and all was great
