De-rust inside or bondo & paint 1st?
Discussion in 'XJ Modifications' started by dubyaohohdee, Sep 20, 2012.
  1. dubyaohohdee
    dubyaohohdee Member
    Prob USA
    Got a "new" xj750 tank for my 650. Should I Paint & Bondo 1st and then remove internal rust? I think so, as tank will need to be empty and unprotected during paint.
  2. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    My method has always been to paint and clear as the very last step no matter what. Otherwise I might damage the finish during the other work. If you use phosphoric acid to etch the tank or even coat it with MM oil you'll have time to paint before you need to refill it.
  3. wizard
    Strip the paint from the outside, get a sealer kit, POR 15 or similar, the kit will contain a de-rusting chemical, sealing the tank is a messy business & should be done before painting the tank.
