Deer Skin Seat Cover
Discussion in 'XJ Modifications' started by TheCrazyGnat, Sep 14, 2016.
  1. TheCrazyGnat
    Central PA
    My seat has a decent size tear in it from my stubby legs scraping my boot heel on the seat while throwing a leg over. I was thinking about reupholstering the seat myself using the diymotorcycleseat.com instructions and was wondering if anyone has used deer skin for this and, if so, how that worked out for them. I've heard it is a little more pliable than the leathers/material you would normally use. I was thinking that would be a great way to do this cheap and, even if it didn't turn out great, or not as durable as the original, I could just make one every couple of years.
  2. Polock
    leave the fur on
  3. dkavanagh
    Rochester, NY
    I never know when you're being serious, which mean your replies often amuse me.
  4. TheCrazyGnat
    Central PA
    I was thinking that would look cooler, but maybe would get nasty sooner. I had a really nice looking buck walk 20 yards in front of me 2 years back that would have made a real attractive seat, ha ha. Too bad he only had 2 points on one side and was missing the other.
  5. k-moe
    It'd be comfy for the annual naked ride.
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Oh dear!
    Josh Taylor, BigT and Stumplifter like this.
  7. TheCrazyGnat
    Central PA
    Going buck naked. Well, now I have to.
    Stumplifter, k-moe and MattiThundrrr like this.
  8. hogfiddles
    Bolt the antlers onto the front fender
  9. hogfiddles
    Fair warning, though......buckskin will stretch and sag like crazy if it gets wet.......you'd have to do some serious waterproofing...it's also very thin and weaker compared to horse/cow/etc.... leather......so durability could present an issue .
  10. TheCrazyGnat
    Central PA
    I've heard that out stretches more significantly than other leathers. I was thinking that it would probably get pretty nasty when wet if I did leave the fur on. I figure that my first go at this will probably turn out crappy, so the shorter life span isn't too bad. I haven't tanned a hide before either, so there are plenty of ways this could go wrong. I figure I'm not out much either way though.
  11. REVELCAL
    REVELCAL Member
    Rapid City, SD
    Buckskin aught to last you just fine, its pretty durable. I made my seat out of brown suede - which I was told not to use because its too fragile - and my seat has lasted 2 summers un-garaged with no signs of giving up any time soon. The color is a little different now, and after getting sick of buying saddle soap to waterproof it I just started rubbing old oil into it. Anyway, assuming you take better care of your buck skin than I do my suede it will last you quite a while.
  12. TheCrazyGnat
    Central PA
    Cool, I'm really getting interested to try this out now, ha ha.
