Determine Key Code
Discussion in 'XJ Technical Chat' started by ralden96, Sep 15, 2021.
  1. ralden96
    ralden96 Member
    new york
    Looking for some help. Recently purchased a barn find 1981 Seca 550 (no where close to running). It came with an aftermarket key which works all 3 locks (ignition, gas cap and seat lock). I'd like to find the key code but the sticker on the underside of the ignition module has long since disappeared. Is it noted anywhere else on the bike or can it be determined through the aftermarket key? TIA
  2. JCH
    JCH Active Member
    seattle wash
    I think the steering column has a sticker that may help, did you do a search on the right upper corner ?
  3. ralden96
    ralden96 Member
    new york
    I didn't see anything but will look again. Thanks.
  4. Dan Gardner
    Minneapolis, MN
    There is a code on the underside of the ignition switch assembly. This is a picture of me trying to read it with a mirror.
  5. Dan Gardner
    Minneapolis, MN
    Sorry, just noticed in the original post that said sticker is gone. I think you can just get the key duplicated.
  6. XJ550H
    is there a number on the key?
    there are several styles of yamaha keys with the correct blank you can have the key cut.
    I would think a locksmith could measure key and give you the code
  7. Timbox
    Timbox Well-Known Member
  8. kosel
    MInneapolis, MN
    There are locksmiths on eBay that will make your key if you send them the keycode. I ordered two that way and they work just fine.
