Dies at stops??
Discussion in 'XJ Technical Chat' started by hawaiianice99, Jul 13, 2010.
  1. hawaiianice99
    hawaiianice99 New Member
    my '81 xj650 will start up fine and ride ok but when i come to a stop it will die. I have to turn the key off for a minute, put the bike in neutral, then turn the key back on and hope the lights come on cuz it can take a couple tries. any ideas?
  2. tjb2of3
    tjb2of3 Member
    Charlotte, NC
    Hmmm... once it dies, do you always get lights? Or is it sometimes lights, sometimes nothing?
  3. hawaiianice99
    once it dies i have to let it sit for a minute, i put it in neutral and keep checking the key. once the neutral light comes on i know i can start it up again. i usually have to let it sit for at least 30sec.
  4. wizard
    bad fuses or ground
  5. hawaiianice99
    fuses are all good, what ground?
  6. wizard
    All of them, the main one to the motor & depending on your model there could be a couple to the frame & clean & tighten the battery terminals & the starter relay.
  7. BlackMax
    BlackMax Member
    Brampton Ontario
    could be your clutch saftey switch as well,Which would explain why you have to put it in neutral to restart it.....l
  8. hawaiianice99
    clutch safety switch?
  9. BlackMax
    BlackMax Member
    Brampton Ontario
    Its connected to the side stand,if you try to put it in gear it will die,(with side stand down)
