Differential pressure relief valve
Discussion in 'XJ Technical Chat' started by HalfCentury, Mar 8, 2009.
  1. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Washed the bike yesterday.
    While using a VERY soft brush on the differential the cap that is located on top came off. Underneath is some crusty looking dried-up adhesive.
    Can I just clean this thing up and re-glue it?
    If so, what sort of glue do I use?
  2. fuferman
    fuferman Member
    Kettle Falls, WA
    well sounds like the PO twisted it off those i think were spot welded. i say that because i tried gently to pry mine up and it dimpled in the middle where it was attached. there should be a vent hole under there somewhere make sure it isn't full of "crusty looking dried-up adhesive"
    although someone said his was pushed down too far so there may be some adjustment but i don't see how. let us know how you get it back on
