Does anyone have a minimum wiring diagram?
Discussion in 'XJ Modifications' started by krayzeesmoke, May 23, 2010.
  1. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    I am going to be rebuilding my 82 xj750 seca, but first I have to start by saying that I do not have a clue what I am doing, but feel confident enough in the vast wealth of knowledge on this site that I went for it!
    It may also mean that I am not the brightest :D
    I have began the tear down portion, and have removed the wiring harness, a bunch of the connectors were cracked and brittle (so I will need to replace those) and it leads me to believe that re-making a new harness is the better way. I am also removing the fish finder dash (although, I currently do not have a replacement) :?
    I need to know what would go in a rebuilt harness :oops: just the basics, headlight, taillight, blinkers, ignition, etc (notice the "etc", in this situation, it means that I am drawing a complete blank and REALLY need somebody to tell me exactly what is needed)
    Any help would be extremely well received. Thanks in advance, and once I figure out how to post pics direct, I will, until them they will be in my gallery.
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    it has been posted here dozens of times...Moderators, please make it a sticky...
  3. streetbrawler750
    streetbrawler750 Member
    Minnesota
  4. pitmonster
    pitmonster New Member
    I also would like one for my 82 XJ 1100. I used the engine in my sons pulling tractor and need help getting the minimum wiring with no lighting or anything. I just want to make it run!. Can you help me I am new here so be easy on me. And please,the simpler the better.
  5. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    Thanks Street, I am probably going to end up using the original harness, take away whats not being used, then make a new harness with fresh wires out of whats left.
    Considering I am also not 'electrically' inclined, this seems the easiest way.
  6. streetbrawler750
    Minnesota
    Definately use the search function there has been recent trouble shooting on this subject, and lots of info on wiring.
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
  8. pitmonster
    And one more thing,their is a box with wires going to it and a fitting for a vacum line that says"boost sensor,what is that and do I need it?? If so where does it wire in,.I don't see one in the wiring diagram for the "XJ" series listed here??I am assuming that it's the electronic vacume advance that I would like to bypass if possible. The color combination on the wiring is quite different on the 1100 than what is shown on the diagram I have found here.
    Thanks.
  9. ol_750
    ol_750 Member
    Newcastle Australia
    Try this
